using diodes to step up voltage
Update:
1998/99 s10 2.2l
Stock alternator
Single wire from engine wiring harness - modifications with diode has no effect
had to modify the stock terminal to accept and additional wire on the "S" pin.
Pulling from batt +, diodes inline to "S", mod works
I will add some picture to this thread showing the terminal modification needed or you can purchase an aftermarket terminal with all 4 leads.
I'll add various test results also with different diode packs.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I have a '97 Grand Prix and just ordered one of these for $21.99. ( I got the stage 2 that raises voltage by 1.2 volts).
I will keep yall posted on how it works...
http://www.zzperform...d=517&catid=107
http://www.zzperform...s_img/517_1.jpg
Those links didn't work, BUT the site looks fimilar. If its those .6 or 1.2 voltage booster thing off the factory harness THEY DON"T WORK! bought one and it didn't do anything!
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Sorry, mine did! They are from ZZPreformance.com
Pontiac Grand Prix GT
400a Mean Machine alt.
EIGHT DD 12''s on a DDz2
DD vo 8''s,6''s,5.25''s&tweets
Norfolk, VA
http://www.youtube.c...ser/ovnorfolkva
https://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishova
http://www.stevemead...__fromsearch__1[/color]
  • 2 months later...
can i used a 1n4004 on my 2005 g6 it only has one wire so i just cut tap with the gray stripe pointed at the alt
not sure on that one. might be computer controlled. ill be doing my burban tomorrow
So if the car is PCM controlled are we better off getting an MLA or something? I know mine has the 2 pin alt with grey and orange wires and that stupid ground induction sesor that Underlok was talking about. 06 pontiac pusuit. angry.gif Coudn't find one wiring diagram for the dman thing lol
I have a 2007 Chevy Cobalt with the sensor on the ground wire. Its a hall effect sensor. Its basically a magnetic field sensor. Wonder if there is a way to somehow fool it with a magnet to trick it to thinkin that there is a load to keep the voltage up?
I have a mla on my 07 escalade its pcm controled. The thing is it work sometimes that or I hooked it up wrong. Il get 14.4-14.7 charge but I have to unground my battery if it sits over 8or so hours. Im looking for an other way. Im tired of having to remove the grounds on my battery evetytime I use it.
I wonder if the computer is not over riding it somehow.
  • 7 months later...
Anyone still doing this? trying to figure out the sensing wire for my 99 jeep cherokee 4.0
I dont think this works on Mopar.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Anyone know if this will work for a 2000 Nissan Altima 2.4L GXE?
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
  • Who's Online   1 Member, 0 Anonymous, 1553 Guests (See full list)
