korey_hofer Posted May 3, 2011 Report Share Posted May 3, 2011 you can't sand mdf smooth Quote previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street. Link to comment Share on other sites More sharing options...
n8ball2013 Posted May 3, 2011 Report Share Posted May 3, 2011 If you are trying to accomplish a smooth finish on mdf you need to seal it. be it resin or filler or something. otherwise it will soak up paint. If you have an edge that was cut you will never be able to stop it from soaking up and be able to get a smooth finish. did you even look at the link Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Mtnbikecrazy55 Posted May 3, 2011 Report Share Posted May 3, 2011 If you are trying to accomplish a smooth finish on mdf you need to seal it. be it resin or filler or something. otherwise it will soak up paint. If you have an edge that was cut you will never be able to stop it from soaking up and be able to get a smooth finish. did you even look at the link Bookmarked. Damn that looks good. And diddnt look too difficult if you have the patience. Quote I hate long signatures.... ...what the fuck is wrong wiht you you fucking fuckity fuck fuck head... Mtnbikecrazy55 Feedback Link to comment Share on other sites More sharing options...
Tek Posted May 3, 2011 Report Share Posted May 3, 2011 not to thread jack- but if you are going to use bed liner to paint it with, do you still have to prime or resin it? Quote Link to comment Share on other sites More sharing options...
xterraboy03 Posted May 3, 2011 Report Share Posted May 3, 2011 not to thread jack- but if you are going to use bed liner to paint it with, do you still have to prime or resin it? I never have, I just sanded the box to make sure all my edges were smooth and the flat surfaces had some sand time to ensure a good hold. I just layer up on the coats on the edges, you can still see an edge where it soaked up a little bit more, but if you're doing bed liner it doesn't have to be perfect. Quote 03' NISSAN XTERRA (1) AQ3500d (1) AQ4x90 (1) Audio Control Line Driver (4) DC LVL 4 15's Cresendo Mids and Highs 100' of 0/guage Big Three Mechman 270a Charging @ 16.5v (6) XS D1400's Highest Termlab Score 149.9 at the kick & 166.1 in the Port/ on stock electrical and 1 DC XL M1 Updated JUNE 2012*****MY BUILD LOG USACI REGION 6 POINTS LEADER 2011 USACI KANSAS RECORD HOLDER 2011 Team DC http://www.dcsoundlab.com/ Link to comment Share on other sites More sharing options...
xterraboy03 Posted May 3, 2011 Report Share Posted May 3, 2011 If you are trying to accomplish a smooth finish on mdf you need to seal it. be it resin or filler or something. otherwise it will soak up paint. If you have an edge that was cut you will never be able to stop it from soaking up and be able to get a smooth finish. did you even look at the link yea I read the link, and yes if you want to have the most ba box with no paint soak then yea you might as well pull out the resin and filler. I was just trying to give a couple other options to people that have never resin'd or didn't want or have the time to. Quote 03' NISSAN XTERRA (1) AQ3500d (1) AQ4x90 (1) Audio Control Line Driver (4) DC LVL 4 15's Cresendo Mids and Highs 100' of 0/guage Big Three Mechman 270a Charging @ 16.5v (6) XS D1400's Highest Termlab Score 149.9 at the kick & 166.1 in the Port/ on stock electrical and 1 DC XL M1 Updated JUNE 2012*****MY BUILD LOG USACI REGION 6 POINTS LEADER 2011 USACI KANSAS RECORD HOLDER 2011 Team DC http://www.dcsoundlab.com/ Link to comment Share on other sites More sharing options...
