Ahh well i just looked up that sub 21" thats crazy. well it says its rated at 1500 Rms. Soooo i would get one AQ2200 and one of those in a dual 2 verson and run it at 1 ohm
2000+ watts rms to a 1500 rms sub will make it slap.
Plus with that amp you would only need 2 battries, a HO Alt and a bunch of 0 Gauge.
so those ratings on the aq were at rms power? i thought those were max ratings
i'm sure that DP will handle 3l no problem in the hands of someone who knows what there doing
but for 16 year old who's just getting into this stick with an aq 2200 for now and maybe later down the road get a second but for now dont go spending all your moniezzzzz
edit and the DP is a duel 1 or duel 2
so look at these ratings
.5- or 2 ohms- or 1-4 ohms
R.I.P!
(Nov-29-2009)
92 explorer
current build
....read the site? That is it's rms.
1500 watts RMS/3000 peak
Umm?
I was talking about the AQs. It was directed at OP.
-98' Ford Expedition (Rest in Peace)
-AVH-P3300BT
-Crescendo BC5500
-4 18" DC m2 Level 3.
i saved up about 3k so far but i see this as an investment lol
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Umm?
sorry man just realized that lol
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
with a dual 2 ohm speaker you can get a one ohm load
they are RMS but since the sub is 1500 RMS like powerhouse407 said a single AQ2200D would be a good match and you dont need crazy electrical to run it
well i i think i got the electrical figured out 280 amp dc alt and 2 d3100's or a d3400 and a d3100
Yah that will be Plenty of Power for a AQ2200D you would run over 14V at all times. Just with this much money going in to a build. take your time reserch and do it right. dont rush and mess up somthing. also try to find some one in your area who has an O-scope so you can make shure you are not clipping anywhere. then you will be set.
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
i wonder if they charge more for the dual 2 ohm because they only list 1 price
but if you cant get ahold of a o-scope the AQ2200D has a clip light so atleast you know you wont be sending a clipped signal to the sub
Lanzar VCT3000D oh yeah!!!!lmfao
(2007 Chevy Tahoe LT)
Mechman 320A
OEM AGM
D'Amore Engineering HLC-2 Sig Converter
D'Amore Engineering E1500.1
Fi Audio Neo 3.5 12"
No.... unless it was somthing they dont offer and had to build it.... also how much is this sub???
  • Who's Online   0 Members, 0 Anonymous, 6888 Guests (See full list)
