J.Reed Posted April 22, 2011 Report Posted April 22, 2011 i´ve doing this with sweeps for a long time with good results, anyways, everyone do whatever you like and that´s it, i own a termlab and i can find peaks much easier than trying to do it blindsided What happens when the sub is hotter then when the sweep started to get to the actual "peak"? It can change the way the sub reacts. CHanging what is seen as peak to what is actual peak. Also with a sweep voltage drop can effect the true "peak". Thats all I'm saying. Also running a sweep at different power levels can effect where it is peaking. Sweeps are not 100%. Going Hz by Hz and with the exact same everything is what will do it 100% and thats with a 100% flat enclosure. Just like measuring wavepath to find resonant. Sure it may work quite a bit or be really close. But to be 100% its Hz by Hz and lots of testing. You wanna get loud ya gotta put in work END of story.
fecupe2001 Posted April 22, 2011 Report Posted April 22, 2011 i´ve doing this with sweeps for a long time with good results, anyways, everyone do whatever you like and that´s it, i own a termlab and i can find peaks much easier than trying to do it blindsided What happens when the sub is hotter then when the sweep started to get to the actual "peak"? It can change the way the sub reacts. CHanging what is seen as peak to what is actual peak. Also with a sweep voltage drop can effect the true "peak". Thats all I'm saying. Also running a sweep at different power levels can effect where it is peaking. Sweeps are not 100%. Going Hz by Hz and with the exact same everything is what will do it 100% and thats with a 100% flat enclosure. Just like measuring wavepath to find resonant. Sure it may work quite a bit or be really close. But to be 100% its Hz by Hz and lots of testing. You wanna get loud ya gotta put in work END of story. I use DD, my subs don´t get hot with a sweep with a LOW volume my friend, also, i have a nice Mechman and 3 big ass batts in there so my voltage doesn´t drop using a low volume on a single 12" with a sealed box... Oh by the way, i´m loud I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
fecupe2001 Posted April 22, 2011 Report Posted April 22, 2011 double post FTL I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
TeamHT Posted April 22, 2011 Report Posted April 22, 2011 Loud...psh...LOL Tell me...does this smell like chloroform to you?
J.Reed Posted April 22, 2011 Report Posted April 22, 2011 i´ve doing this with sweeps for a long time with good results, anyways, everyone do whatever you like and that´s it, i own a termlab and i can find peaks much easier than trying to do it blindsided What happens when the sub is hotter then when the sweep started to get to the actual "peak"? It can change the way the sub reacts. CHanging what is seen as peak to what is actual peak. Also with a sweep voltage drop can effect the true "peak". Thats all I'm saying. Also running a sweep at different power levels can effect where it is peaking. Sweeps are not 100%. Going Hz by Hz and with the exact same everything is what will do it 100% and thats with a 100% flat enclosure. Just like measuring wavepath to find resonant. Sure it may work quite a bit or be really close. But to be 100% its Hz by Hz and lots of testing. You wanna get loud ya gotta put in work END of story. I use DD, my subs don´t get hot with a sweep with a LOW volume my friend, also, i have a nice Mechman and 3 big ass batts in there so my voltage doesn´t drop using a low volume on a single 12" with a sealed box... Oh by the way, i´m loud Loud you say? So I must be uber loud doing 153+ in a larger vehicle and half your power with a daily flat playing enclosure?
TheyDontWantMusic Posted April 22, 2011 Report Posted April 22, 2011 Loud you say? So I must be uber loud doing 153+ in a larger vehicle and half your power with a daily flat playing enclosure? so if its a "flat playing enclosure" it must do 150+ at 20Hz then?
korey_hofer Posted April 22, 2011 Report Posted April 22, 2011 external dimensions, 18mm MDF, seeing as you think that magically having the dimensions will turn it into a ported box so cmon, I'm still waiting for someone to model this as a ported box? why would I do that? waste my time with a shitty design jsut to prove that I was right? I'd rather sit here and not care previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
TheyDontWantMusic Posted April 22, 2011 Report Posted April 22, 2011 external dimensions, 18mm MDF, seeing as you think that magically having the dimensions will turn it into a ported box so cmon, I'm still waiting for someone to model this as a ported box? why would I do that? waste my time with a shitty design jsut to prove that I was right? I'd rather sit here and not care sounds like admission that you're wrong. thanks for your time.
TeamHT Posted April 22, 2011 Report Posted April 22, 2011 how about this, since youve declined as well (hypocrite much?). please explain how its NOT a ported enclosure? Tell me...does this smell like chloroform to you?
korey_hofer Posted April 22, 2011 Report Posted April 22, 2011 far from admitting anything just not wasting my time proving your wrong to only have you try and pull an excuse out of your ass. previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
