flashlight_65 Posted April 14, 2011 Report Posted April 14, 2011 Any suggestions? Pretty much under the truck with a 4" hole in the back somewhere (probably just behind the rear seat on the driver side) I'm stationed out in rainy Washington state but eventually I'll be moving back the Minnesota and want it to be protected against the elements and road salt. Will the jacket suffice on the knu wire or does anyone have any other suggestions on running or protecting it. Quote My builds: my caddy my 'hoe friends impala
mr.p Posted April 14, 2011 Report Posted April 14, 2011 holy hell 10 runs of 1/0...when i run it under car i usually use welding or marine wire with the hard plastic jacket...ill be using knu and will just use rubber mounts and stick it to the frame...the rubber will be fine long as it doesnt rub. Quote DCAUDIO BALLS DEEP
flashlight_65 Posted April 14, 2011 Author Report Posted April 14, 2011 I'll be using these along the frame for the first few runs using stainless hardware and then use some heavy duty zip ties for the rest if I leave it exposed Quote My builds: my caddy my 'hoe friends impala
dwright27 Posted April 14, 2011 Report Posted April 14, 2011 put the wire in PVC pipe. problem solved Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
mr.p Posted April 14, 2011 Report Posted April 14, 2011 roger that sir exactly what i use Quote DCAUDIO BALLS DEEP
flashlight_65 Posted April 14, 2011 Author Report Posted April 14, 2011 I thought about that too or in that grey electrical conduit but am worried about moisture getting trapped in the tube and just chilling in there especially back home with the repeated freeze and thaw Quote My builds: my caddy my 'hoe friends impala
flashlight_65 Posted April 14, 2011 Author Report Posted April 14, 2011 Fuck it, I'll just do 60 runs of 8 gauge spread under the carpet Quote My builds: my caddy my 'hoe friends impala
JMac91 Posted April 14, 2011 Report Posted April 14, 2011 Fuck it, I'll just do 60 runs of 8 gauge spread under the carpet What the Quote Vehicle: 2002 Volvo S60 2.4t awd.Headunit: Kenwood DDX-470Doors: 4x Focal 6.5s/tweets (Adding)Sub: 2x Sundown Zv4 12's D1Amps: B2 Zero.1, MB Quart OA600.4Box: 5.2ish @ 32, Made with Maple, solid oak braces, 45s all around, 2x 5.8" pipes, all fiberglassed up.Battery: XS D3100, Block Shakers 110AHAlternator: 250A Excessive Amperage. All Sky High OFC Wiring. My Build, plenty of pics: http://www.stevemeadedesigns.com/board/topic/198281-2002-volvo-s60-awd-24t-build-log/
S15_Silvia Posted April 14, 2011 Report Posted April 14, 2011 Drill a few small holes along the length of the pipe to let out trapped water...bada bing Quote 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
flashlight_65 Posted April 14, 2011 Author Report Posted April 14, 2011 But it would let the nasty salty sand slush in too. Quote My builds: my caddy my 'hoe friends impala
