10,116 Rms In A Hatch - Videos - 152.3 Bass Race On Tl - Updates
is it possible (within your budget) to fabricate a bracket for another alt at the expense of saaaay your AC compressor?
i think that may make more of a difference than getting powermasters imho
The hump in the middle is for the exhaust, shift linkage and the e brake. Are you using anything in the wheel well?
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
  • 1 month later...
donno anything bout those amps really but what about trying a 16 volt setup
R.I.P!
(Nov-29-2009)
92 explorer
current build
I would almost bet money, you would see a change for the better with 2 PM D3100's over the 2 2400s
I would sell the 2400s buy the pm d3100s dump the ac and fab up a bracket for another alt gm big case 300 amper.
^^ Doesn't the t4k draw 500amps a piece? If so I would think you would need atleast that 180amp alt and a 300amp large case.....I myself wouldn't run anyless that 4 d3100s with that setup.
edit: I don't like voltage drop. You might also want to look into a MLA module, if you don't already have one.... Also I wouldn't keep letting that voltage drop that low or gonna be replacing or buying new amps.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Went back and reviewed the subs and see that you put them directly in the middle of the box if you put them to the left and then put that batteries onto of the box to the right you could easily fit 4-5 d3100s in that car...
Posted Image
My YouTube Videos
or you could mount the batteries inside the box in the middle and install charging posts on the back side of the box, and then add two more subs to the box.
Deep Sector Boom...
LOL whatever it is your smoking I want some.
that's what i was thinking
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
