XS Power
Alright first off.. I was thinking of getting a d5100 for a system that should be around 2500rms, and as a second battery. The amp is a power acoustik gothic series (ovn1-5500d) and will be wired @ 2 ohms = 2500rms with an AA Mayhem 18" d2 (Might upgrade to AQ2200d in the future but need a battery now) The one at the hoods just a basic battery.. but another thing, if I were to buy this battery (assuming its a good choice any opinions?) what do I need to do to it. I heard u gotta charge these types of new batterys first so .. idk how to go about that exactly.. or if I have anything to.
Also, Is this correct for wiring a second battery?
I know what your all thinking.. im a fucking artist.
I get that alot.
But thanks in advance.
Edited by JMac91
Vehicle: 2002 Volvo S60 2.4t awd.
Headunit: Kenwood DDX-470
Doors: 4x Focal 6.5s/tweets (Adding)
Sub: 2x Sundown Zv4 12's D1
Amps: B2 Zero.1, MB Quart OA600.4
Box: 5.2ish @ 32, Made with Maple, solid oak braces, 45s all around, 2x 5.8" pipes, all fiberglassed up.
Battery: XS D3100, Block Shakers 110AH
Alternator: 250A Excessive Amperage.
All Sky High OFC Wiring.
My Build, plenty of pics: http://www.stevemeadedesigns.com/board/topic/198281-2002-volvo-s60-awd-24t-build-log/
anyone?
And what about my alternator its fine just wired to the 1 battery?
Looks OK. I'd suggest running a ground from the back battery to the front battery so it's connected completely in parallel. + to +, - to -
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
x2 and if its 12.6 volts or higher you dont need to charge it you can just put it in, and a d5100 is supposed to be good for 2000 watts as primary or 3000 as a secondary battery
Paint diagram.
Win.
I have nothing to say so i'll just post a reply to raise my post count... <_<
The amp you have won't put out 2500w at 2 ohm...
Audioque will put out more power at 1 ohm.
dont forget that other fuse, here is my guide for doing this, follow it
Dereileaks Wiring Guide Link
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
  • Who's Online   0 Members, 0 Anonymous, 1499 Guests (See full list)
