bassrace Posted May 8, 2011 Report Share Posted May 8, 2011 I need to know if my 2008 model orion D5000 is stable for daily use at a .25 ohm hopefully someone on here has experience with this amp at that low of impedence. I have big 3 and XS power deep cycle. 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
zayres29 Posted May 8, 2011 Report Share Posted May 8, 2011 why not just buy the right coil combinations and wire it how its supposed to be Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged Link to comment Share on other sites More sharing options...
corey0928 Posted May 8, 2011 Report Share Posted May 8, 2011 Why would you run at .25 daily? Link to comment Share on other sites More sharing options...
korey_hofer Posted May 8, 2011 Report Share Posted May 8, 2011 .5 is only as low as I have seen. I might try my dd m2 at .25 daily to see how it works previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street. Link to comment Share on other sites More sharing options...
Azagtoth502 Posted May 8, 2011 Report Share Posted May 8, 2011 Unless you want to blow it up, I wouldn't recommend it. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls Link to comment Share on other sites More sharing options...
bassrace Posted May 8, 2011 Author Report Share Posted May 8, 2011 Im at 1 ohm now i wanted to see how much more power i would get at .25 ohm 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
bassrace Posted May 8, 2011 Author Report Share Posted May 8, 2011 why not just buy the right coil combinations and wire it how its supposed to be I have 2 dual 1ohm subs wired to 1ohm which was ideal at the time 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
audiofanaticz Posted May 8, 2011 Report Share Posted May 8, 2011 I wouldnt do it.. they are pretty basic underbuilt amplifiers imo. Not only if you have to ask if it will, that pretty much should tell you to not do it! Also you dont even know your impedance rise @ 1 ohm let alone knowning if .25 would be safe for a burp, let alone daily.. Those amps can be very picky, and will blow easily! Its only a 2500 watt rms amp. If you need more power buy a bigger amp! or risk it constantly going into protect, blowing the powersupply mosfets, or having way to much current and distortion burning up your speaker tinsels making you need recones. Link to comment Share on other sites More sharing options...
bassrace Posted May 8, 2011 Author Report Share Posted May 8, 2011 .5 ohm is fine for this amp i know personally but i wasnt sure bout .25 ohm i dont need more powa foreal i just wanted to test my limits man 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
Elrey7698 Posted May 8, 2011 Report Share Posted May 8, 2011 Curiosity killed the cat homie...in ur case the amp.... .25ohms? Boy u trippin Link to comment Share on other sites More sharing options...
