what would you recommend the lowside reading be with the pump on?
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Are you sure the fan is coming on with the a/c?
We had an older honda civic that the a/c would work for a little, and then cut off because the fan wasn't coming on, new motor solved it.
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
Fan is hardwired to a switch so its definitely on when i turn the a/c on
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Honestly, best course of action is to take it to the A/C place.
And this is also a probability.
If your fan isn't keeping the condenser cool, you'll have bad performance.
ok you really need to do a little more research with google. there is a ton of info everywhere on this. also realize there are 2 test ports. one is high side pressure and the other is low side. YOU CANNOT READ HOW MANY POUNDS OF FREON IS IN THE SYSTEM!!! literally impossible unless you weigh a bottle and empty the system into the bottle and them re-weigh it. it could be weigh over charged from messing with it and not knowing what your doing. also those autozone re charge systems do work but make sure you read the instructions 100 percent and follow them or else it wont work. best bet is to stop spending pointless money on recharge kits and go to a local shop and pay the 20 bucks to have it recharged. they will empty and refill it. takes like a half hour of your life...
some of those systems on that car has a "variable flow compressor" which means the compressor always keeps running. The compressor varies inside to change the flow instead of the clutch coming on and off. I know some of the late 90's cavaliers worked that way. The pressures will change slower instead of an on and off type of compressor.
99 GMC Suburban
2 Death Penalty 21"
2 Crescendo BC2000
Boston GT-42 Amp
6 Selenium 6w4p
4 Crescendo tweets
Hi output cs144 alt
Audiocontrol Epic-160
Pioneer DVD head unit
