tonedeaf Posted May 17, 2011 Report Posted May 17, 2011 (edited) So I have an older set of hsk165 components and am about to order a new set. I was curious, for those who have run these before, how much power do these thugs like? Ima be running a new and old set in each door and have read these things like power. They are rated for 125 but ive read 150ish is a sweet spot. Any suggestions on this? Also, hertz suggests a pillar mounting for the tweets. Would this be the best place, or should I mount them like I've read within 12" of the mids? (would mount them in the same pods as the mids). Thanks, Tonedeaf Edited May 21, 2011 by tonedeaf Quote
Skullz Posted May 17, 2011 Report Posted May 17, 2011 Can't say i know the limits of them but i'm running 125w x 4 on mine at the moment and enjoying them and as beefy as they are i would think 150w or more is quite possible. This guy says in the notes he is giving them 420w rms. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Reilly Posted May 17, 2011 Report Posted May 17, 2011 What James said.... Ive run 200+. The problem with going over 150 is the tweeter. Fine for a few, kinda like overpowering a woofer, but 10x more sensitive to clipping death, thermal, or overboosting the treble. Quote Clovis Custom Audio 559-392-3600 96 Silverado Single Cab 2-DD9515's Cut-through 1-DDSE Amp Stock electrical and a couple small stingers, LOL
n8ball2013 Posted May 17, 2011 Report Posted May 17, 2011 Ive got mine on a aq 4x90 Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Reilly Posted May 17, 2011 Report Posted May 17, 2011 Active? I love my Hertz active! Quote Clovis Custom Audio 559-392-3600 96 Silverado Single Cab 2-DD9515's Cut-through 1-DDSE Amp Stock electrical and a couple small stingers, LOL
tonedeaf Posted May 17, 2011 Author Report Posted May 17, 2011 Yeah I'm looking off eventually running them off a jbl m8 or audison bitone. Was gonna grab a aq 90 but I want to give them atleast 125 per side and have as much sq as I can get along with the ability to crank the volume, so I decided on the Zuki eleets 4 channel, that's been clocked at nearly 200 per channel. Should be able to run both sides perfectly once I get a scope to set the gains. Thanks for your help guys. Quote
tonedeaf Posted May 21, 2011 Author Report Posted May 21, 2011 Was curious as to how low I can expect the 4 6.5s to play. Im wanting the mids to bridge the gap between my mids and subs (as they are meant to be). Im really wanting mids capable of dropping down to 50htz and if I need some 8" shallows or something for a bit more depth along with the 165s so be it. Any suggestions are appreciated. Quote
AI James Posted May 21, 2011 Report Posted May 21, 2011 Your sub should be playing 50hz anyhow. But anyhow properly crossed over they should easily play 50hz up Quote
tonedeaf Posted May 21, 2011 Author Report Posted May 21, 2011 (edited) Your sub should be playing 50hz anyhow. But anyhow properly crossed over they should easily play 50hz up It does, but I lose high end very quick with one sub tuned @ 28hz. I was just wanting to make sure these should push 50hz relatively fine. Now to read up on speaker aiming. Edit: Also on the list down the road is buy 3 more 15s and do a back seat fourth order/wall so I dont need to worry about losing the highs while getting my lows. Edited May 21, 2011 by tonedeaf Quote
