AQ3500.1 specs?
TIG
I bought one of the older models with the single power ground inputs and I cant find any specs on them. Anyone know specs from 2ohm to .5 ohm?
Since were all having a moment of truth.
I hate country too..
I'd only listen to it if I got some hotass bitch in my car and shes gonna suck my dick.
BUMP
iirc they can't be run at 2 ohms, well maybe they can but they're powers not listed. you'd have to do the math.
4 ohm power @ 1% THD 750W x 1
1 ohm power @ 1% THD 3,500W x 1
1 ohm Power @ 16V @ 1% THD 4,000W x 1
1 ohm Power @ 18V @ 1% THD5,100W x 1
1 ohm Power @ 18V @ 10% THD 6,500W x 1
2006 Nissan Z Track.
My Feedback Thread
i used to think a band pass was something you were around your neck or something.
how can an amp not be run at 2 ohms when its 1 ohm stable?
Well...you have the amp now...clamp it.
The ratings were conservative for the board, and I don't think changed from the 3500 to the 3500.1. Only difference were the dual inputs.
I didnt thin they changed either, thanks for the input.
The AQ3500D is rated at 3500@1ohm, 1860@2ohm, and 990@4ohm
The AQ3500D.1 is rated at 4300@1ohm, 2600@2ohm Ratings are at 14.4 volts@less then 1%thd except the 4 ohm rating for the AQ3500D.1 is 750@l2 volts with less then .05 thd.
  • Who's Online   1 Member, 0 Anonymous, 1183 Guests (See full list)
