AQ3500.1 specs?
TIG
Well...you have the amp now...clamp it.
The ratings were conservative for the board, and I don't think changed from the 3500 to the 3500.1. Only difference were the dual inputs.
The AQ3500D is rated at 3500@1ohm, 1860@2ohm, and 990@4ohm
The AQ3500D.1 is rated at 4300@1ohm, 2600@2ohm Ratings are at 14.4 volts@less then 1%thd except the 4 ohm rating for the AQ3500D.1 is 750@l2 volts with less then .05 thd.
The amp was always a 4200 board. Clamps of the original 3500s show as much.
Ill bring my clamp and scope to the show.
Remind me.
I have a few clamp results on these new model dual inputs and the board is different between the two model, even the amp size is different. LOL
at 1.375 ohm at 11.5 volts 4200 watts(clean signal)
Then on strapped config(clipped hard) at 14.8 volts did 5500 watts at 6.5 ohm
Then on lower ohm strapped did 9200 watts at 10.5 volts at 1.4 ohms(clean signal)
That is all I have for now.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
I would think the old model would do just north of 3k at 2 ohms and right at 5k at .5 ohm on strong electrical with clipping.
Evo X build log
  • Who's Online   1 Member, 0 Anonymous, 1479 Guests (See full list)
