I have a 2009 Orion HCCA 15.2 in an Atrend SPL vented enclosure, the sub is hooked with 10 awg wire to an MA audio hk4000d(stable at 2 ohms...) I have the sub wired to 4 ohms right now. every time i get the bass bumpin I get a smell.. smells like burning the voice coil(blowing the sub).
I cant figure why it is doing this i must have something wrong...
5/24- fixed the smell the ssf was to low, now i need to findout if i can recone it with different ohms\
160A high output alt.
1/0 gauge big three, cap and amp
30 farad cap.
another question is about a recone kit.. can i change the cone without damaging anything 15.2 to a 15.4 cone?
Edited by dill30669
You are clipping the subwoofer. Turn your gain down, and see if the smell persists. You need to set it with an oscope to get clean unclipped power. :drinks:
Whats your voltage at full tilt? 14.7 starting heavy hits make about 12.7 to 13.8 never had it drop below 12.7 though.
enclosure volume? 3.0 cu ft
enclosure tuning? believe its 35hz?
ssf set to? ssf? need explanation lol
Ssf os subsobic filter if you're tuned to 35 setting your ssf to 25 is a bit low id set it no lower than 30. Also your gains are probably too high
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1379 Guests (See full list)
