P4killer_ Posted June 21, 2011 Report Posted June 21, 2011 So look what came in the mail.. Anyway the amp look great. I hooked everything up. Sitting at .9 nominal. The output was waaay down.. I mean I was just driving 30 mins ago on the 2 channel amp and it sounded great... I got to checking things, fuses. Voltage, impeadence, phase, RCAs, hu, tried using only 1 coil, just everything. Double check all my settings... I checked the output voltage.. good. I even clamped it to make sure im getting which i got 1085w at 1.86 ohms @ 50hz at 11.9v not bad at all... So I have each coil on its own bolt through terminal and the wires marked + and - the only thing i could think of is that somehow i missed marked the terminals and ive got one of the coils backward. being that its a BP , i cant really easilly take the woofer out... I decided to drill a hole in the ported section. I strung some xmas lights in there to see.. and my baffle is like split in half... LMAO OWNED.. i had the woofer mounted inverted.. Fuuuuu ..damn I been basically free airing my sub during testing idk when it happened maybe when i took the box out to put in the crescendo.. anyway i had some lulz and idk when i can build a new box being that i work 54hours / week lol owned. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
tonedeaf Posted June 21, 2011 Report Posted June 21, 2011 I work 70+ hours a week and am fiberglassing my doors atm.
sqsux Posted June 21, 2011 Report Posted June 21, 2011 i'd offer help if i wasn't 3.5+ hours away. Start out boxy, shape as you move along. Dc Audio Team Fur
homiewes Posted June 21, 2011 Report Posted June 21, 2011 i like those new amps My youtube channel, please subscribehttp://www.youtube.com/ballinblaza
Louisiana Bass Posted June 21, 2011 Report Posted June 21, 2011 Amp looks nice mate, sorry to hear about your box. N8. No homo...unless you want there to be.
BeatBox Posted June 21, 2011 Report Posted June 21, 2011 rebuild time! i has the bigger brother to ur amp, havent used it but heard great things from all their new amps!
Supercharged DCs Posted June 21, 2011 Report Posted June 21, 2011 Good thing you thought to check it out, fix the baffle and get us some vids Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
P4killer_ Posted June 21, 2011 Author Report Posted June 21, 2011 Ill open it on thurs and see if i cant temp repair it, as well as try to use some, foam tape to seal the box.. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
