not sayin that this is what it is but it looks like a bad connection maybe in the wire ring. id personally just ditch the fuse between the alt and battery if your just running a stock alt
Edited by moonweezle9
did you have to drill out that ring terminal to fit on that stud? i ask because there is always a lip left over that i file back down flat. i could see a bad connection happening if someone didnt knock that down.
that side of the fuse block looks really close to that metal thing above it. are you sure it couldnt be bouncing up into it?
the fuse block looks to be on sheet metal. is there any chance the bottom of that stud could be reaching the sheet metal? maybe only arcing through the paint under a higher load. just a guess on that one.
is there a lock washer on that side of the fuse block? the lock washer keeps the nut on tight. without it, the nut could slowly back out and give you the bad connection.
also, try smashing the terminal in the vice before soldering. thats what i do. might help, might not.
hope something in there helps.
Edited by skittlesRgood
How does the wire connect to the fuse holder?
If it uses a screw type where you just put the wire into it and tighten it, they suck fucking balls cause they tend to heat and melt wire jackets as the wire loosens from slight movements under the hood. Make your own fuse holder or get one that needs a terminal on it and bolts to the fuse rather than inserting it into a hole and using a set screw to hold it.
damn, then every amp ive ever used must have a shitty connection. think about it.
did you have to drill out that ring terminal to fit on that stud? i ask because there is always a lip left over that i file back down flat. i could steel a bad connection happening if someone didnt knock that down.
No it fit over it brand new.
That thing above is plastic and the the whole holder is screwed down plus there was a cover on it.
No there was a bunch of electrical tape and goop on the underside.
Yeah there was a lock nut under the terminal above it and above the fuse.
Could try that maybe it'll work as of right now I just have a bolt through both terminals holding it together.
--2004 Toyota 4runner
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
spl dust is an option you can get on the coils... it's great for extra 1000 watts of power
where can i get this spl dust and how much is it. is it hard to apply? lol
is the goop touching the terminal on the underside? maybe its slightly conductive?
No there's a little price of white foam directly under the bolt.
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
I know that's why I don't understand lol its fuckin ridiculous.
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
its likely something youve overlooked, did you ever try and run a totally new wire with new terms and all? try a dif fuse block, different fuses, it might be the costly option but hey burning up wire as it stands anyway..
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
  • Who's Online   0 Members, 0 Anonymous, 566 Guests (See full list)
