Alright, so my enclosure in my trunk refuses to stay still... Causing my amps and my box to bounce up and down a good quarter inch.
I built a false floor out of plywood, I'm thinking of taking it out and replacing it with 3/4" mdf.
My box is double baffled on the sub side, there is no panel flex on the wood, but I'm thinking of adding two vertical 2x4's on the inside of the box. Just for extra stability. (also to lower my net box volume, it's a little too big.
I have the false floor bolted through the floor, one on the left and one on the right side, in the middle section. I filled the wheel well with expanding foam...
An the box is bolted to the false floor with 4 L brackets... I would bolt the inside of the box, but because the sub is up firing in the trunk the sub needs to be in the box before it goes in the trunk.
What else can I do?
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
So your sub is moving the box up and down cause the whole false floor to be picked up also?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Make it sturdier
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Its not moving a full quarter inch, i was exaggerating.
One amp is mounted to the front of the box using multiple foam spacers.
Another amp is mounted to the rear of the box.
Then another amp is mounted to the false floor at an angle on the left side of the box...
The entire false floor/box assembly shakes, its the two amps on the box that im most worried about.
The spacers significantly reduced the vibration, but its still bad enough to have me worried.
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
so the sub is moving enough to lift the box up off the floor? easy solution then, bolt that shit down.
one non perminate solutiion you can try prior to any thing else is to use a ratchet strap.
TEAM FLEX ISSUES, TEAM DC AUDIO
2010 California State Finals Champion MECA AS2
2011 California State Champion Meca S2
2011 California State Record holder Meca S2
2012 Meca Mod 4 class 152.5 and rising
I did that when I first installed it.
There is 4 thick L brackets bolting the box to te false floor. Then the false floor is bolted through the floor of the trunk...
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
