Maticus Posted June 25, 2011 Report Share Posted June 25, 2011 I need help with the design process, Rather just what amount of air space in the sealed, and the ported. The only part of the box going into the cab will be the port. I need to know what tuning as well as amount of port volume. I have 39 wide and 15 tall. Length is the truck bed. Quote Link to comment Share on other sites More sharing options...
RooTxBeeR Posted June 25, 2011 Report Share Posted June 25, 2011 I don't know much at all about 4th orders, but from what i have seen in reading topics when people asked questions is that they did it to a 1:3 ratio, guessing its sealed:ported. Don't take my work for that though. Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
slaughter Posted June 25, 2011 Report Share Posted June 25, 2011 Get a design from Ram Quote SOLD 2006 Ford Ranger Single Cab2 DC XL 15's2 Crescendo BC2k's4th Order Blowthrough CURRENT 2012 Dodge Charger R/T 2 Tantric HD 12's Ampere 3800 2 XS XP 3000's Link to comment Share on other sites More sharing options...
JustinWillmon Posted June 25, 2011 Report Share Posted June 25, 2011 Yeah ram_desings just did me a 4th order blowthrough for 4 15" subs. I'd check with him and get something designed. Quote Link to comment Share on other sites More sharing options...
SkylarDunn Posted June 25, 2011 Report Share Posted June 25, 2011 idkw why the hell you guys run 1:3 or 1:2, i wouldnt run anything over 1:1, but i guess i like fidelity. Quote Getting bass into the cabin of a W124 mercedes is impossible. Current setup: Temp 1999 panasonic HU rockford 300.2 for fronts rockford 200.2 for rears rockford 400.1 for sub Leaning towards a 8" in an exponential horn DAMN YOU GERMANS AND YOUR 5" SPEAKERS! Link to comment Share on other sites More sharing options...
uhoh_45 Posted June 25, 2011 Report Share Posted June 25, 2011 idkw why the hell you guys run 1:3 or 1:2, i wouldnt run anything over 1:1, but i guess i like fidelity. my wall was 1:3 and i usually use 1:2 for daily Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
blownengine Posted June 25, 2011 Report Share Posted June 25, 2011 idkw why the hell you guys run 1:3 or 1:2, i wouldnt run anything over 1:1, but i guess i like fidelity. I have NEVER heard of anyone using a 1:1 ratio. Quote 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free) Link to comment Share on other sites More sharing options...
uhoh_45 Posted June 25, 2011 Report Share Posted June 25, 2011 idkw why the hell you guys run 1:3 or 1:2, i wouldnt run anything over 1:1, but i guess i like fidelity. I have NEVER heard of anyone using a 1:1 ratio. usually has do with space restriction Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
Ray Posted June 25, 2011 Report Share Posted June 25, 2011 Id do 2.2cu sealed and 5 ported with 95sqin Tuned to 35ish Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
SkylarDunn Posted June 25, 2011 Report Share Posted June 25, 2011 personally i love 1:.5 compression, they usually have an extremely high fidelity, and can get easily 50hz of bandwidth out of them, but running higher compression is louder, its peaky as hell and doesnt really play a full range of sounds, i'll build some boxes out of OSB next week and show you what i mean. when you run a much larger sealed chamber, you can tune alot higher with the ported chamber, and still get amazing lows, due to the lower F3 in the sealed partition. Quote Getting bass into the cabin of a W124 mercedes is impossible. Current setup: Temp 1999 panasonic HU rockford 300.2 for fronts rockford 200.2 for rears rockford 400.1 for sub Leaning towards a 8" in an exponential horn DAMN YOU GERMANS AND YOUR 5" SPEAKERS! Link to comment Share on other sites More sharing options...
