im going to hold you to your word now..
My word is golden ;)
And I get most of my stickers from ihatestickers.com. Pretty sure that's where I got that one from. I've still got like 25 more that I haven't even put on yet.
Edit for the linky
http://www.ihatestickers.com/random-c-8/get-low-sticker-p-987
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
Here's a better pic of the EQ with and without the LED's on. I know the setting on the EQ for my sub volume and my main volume for when it clips, so it's pretty important for me to see it.
Without the LED's on
With the LED's on
And I just took a 20 minute drive and they really didn't bother my eyes at all.
cant see it out the corner of your eye?
and what do you have for electrical? i forget
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
I'm severely cross-eyed, so my right eye is always on the road.
Fucking kidding lol
I usually keep my eyes up, or my hand resting on the shifter, so it'll block some of the glare.
Stock battery up front, powerware battery in the back. Big 3. 1 run of 1/0 from front to back for now.
i should do my big 3.. got the wire and everything lol.
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
You should notice a more stable voltage when you do it. Just a warning, or a tip.... The run from the alternator to the battery is a pain in the ass. At least for me anyway. I think your engine might be set up differently.
Thanks man!
Well I've also got them hooked up to the switch that controls the voltmeter, so if I'm not wangin' away and needing to keep an eye on my voltage, I'll go ahead and flip the switch and cut the power.
i already scoped out a way to run it, theres a lip above the radiator that the 1/0 fits perfectly into with holes for zip ties (its not touching the radiator and is shielded).
the grounds though.....
i mean can i just run pos from alt to bat and neg from alt to bat? or do i gotta upgrade engine to frame and alt to frame as well?
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
That's the same place I ran my power from alt to battery, but I was saying the pain in the ass is actually mounting the wire to the alt. You gotta bend the terminal on the wire at a 90 degree angle and run it out and around the alt, then tuck it back and run it up to the radiator support.
But when upgrading the big 3 wires, there's no need to run a negative from the alt. Just upgrade the 2 grounds near the battery... Battery to frame, then under the battery is the transmission mount to frame. Then just upgrade the engine to frame and that's it. The stock ground wires are bullshit. 8ga wire at best.... I think mine were just thin, braided steel straps.
