Okay so I took the amp out over night, I cone to hook it back up & it goes right Into protect. Iv checked ground, fuses, power fuse, and connections, all seem to be good. So what do I do? Pretty clueless
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Change grounds or enlarge ground wire first then power wire thickness. Usually protects due to ohm issue or current flow, I.e. yer +/- r touching or not enough juice flowing. R u in same vehicle as when u used it in the past? Alt may be smaller etc...
make sure you dont have as much as a single strand of wire touching someplace its not supposed to. ive seen it before.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Wen you hooked it back up you messed something up.
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
I agree 100% with Nates post. I fried one of my first amps by this. I kept taking the amp in and out to mess with it and one time, the positive came out of the terminal and touched the ground. It didnt spark but it shorted out the amp and even though it worked soon enough i killed the amp. My lesson i learned from it is to connect the wires to my amps FIRST, then hook them up to the battery.
Oh well, live and learn. lol.
  • Who's Online   0 Members, 0 Anonymous, 298 Guests (See full list)
