Mechman dual alt adjustable volt harness caught fire.
So have any of you even contacted Mechman about this yet? It sure does make me feel a whole lot better knowing I am not the only one. Any ideas what causes this issue?
they told me to send it in so they can take a look at it. I offered to even send in one of my alts so they could take a look at it and make sure there was nothing different about it than theirs. I dont expect there to be its an iraggi.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yeah mine are Iraggi alts also.. I bought what what supposed to be 4 300a alts...turns out I got two 220s and two 320s. The 220s they said will be fine but the 320s he said will burn up in a matter of time, plus they only have like 40a at idle. They said they could build them into 270s for like $120 which is what i will be doing.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
Ive been having a weird issue with my alternator from mechman not even charging my batteries, could be my car not wanting so much power though, im going to see what i can do about getting credit back so i can get a different alt for another car
system:
changes way to much...
It almost HAS to be a problem with the alts, don't it? Have you tried an external voltage regulator? Hopefully Mechman helps you get it figured out. But to me from the outside point of view, this does not look good on Iraggi alts. Actually I have seen a lot of people online have problems with them. Isn't that why Steve changed his out from Iraggi to Mechman???
Anyway, good luck, hope to see you get it figured out! :drink40:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
It's really bizarre that the lamp wire is getting so hot unless there is too much resistance? (edit: sorry it's the outside wire so not L just saw yellow and had assumed lamp)
1) Iraggi is done
2) Iraggi (Dom) ripped an assload of people off
You can't say ENOUGH bad things about Dom and Iraggi as far as I'm concerned. I had 3 alts die, 1 due to his OD pulley being too small, 1 because he had sand blasted the case with the damn bearings in it so there was sand INSIDE the bearings, and the third went up in a plume of smoke after playing it full tile for under 1 minute (I drove 2 miles, jumped on it for not even a minute and it went up in smoke literally). His dual alt kit didn't fit, he kept it, and didn't refund me for that or my belt not to mention the cost associated with shipping alts back and forth three times. Fuck him
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
Is that the Lamp light wire or sense wire?
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Ami you have extensive knowledge on the wiring. My hoe has only 1 wire so its easy. My mechman harness works fine. Vcm took a shit but that's another story. On your guys years I'm assuming yellow wire is sense and white lamp? So why not just unhook blue and green. Meaning pull them out of actual plug. Also op take factory plug or avbm and plug it into 2nd alternator alone and see if it works. If it doesn't or starts to get hot then you know its the alternator
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
It's P I think (looks to be far outside wire and if I remember right from outside in it goes PLIS), I just saw yellow in his video and assumed L (the stock harness's I have use yellow as L this one is obviously different).
Pioneer X8500
Second Skin
2 270a Mechman Alts
  • Who's Online   0 Members, 0 Anonymous, 1775 Guests (See full list)
