g6ryder Posted July 3, 2011 Report Posted July 3, 2011 (edited) you cant wire them 2 d2 subs to one ohm, you can wire 2 d4 to a one ohm load and i would go with a the aq2200 u can usually find them used for around 300 just be careful on the gains get the smd dd-1 or a oscope to set ur gains Edited July 3, 2011 by g6ryder Quote www.wooferwarehouse.com
Louisiana Bass Posted July 3, 2011 Report Posted July 3, 2011 you cant wire them 2 d2 subs to one ohm, you can wire 2 d4 to a ohm load and i would go with a the aq2200 u can usually find them used for around 300 Not sure how the SA-12"s will take 1100 rms each, but that's just cause I've never ran em. But OP, like he said, you would need two d4 ohm subs to get a 1 ohm load. Quote N8. No homo...unless you want there to be.
Socky Posted July 3, 2011 Report Posted July 3, 2011 The audioque amps have a clip light to reassure you when bumping them hard. Quote Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
homiewes Posted July 3, 2011 Report Posted July 3, 2011 (edited) either way id go with a mono for any sub setup.. I'd take a DC12k over a Sony Xplod amp any day well dc 12k doesnt count butt id rather have the dc 9k anyways.. Edited July 3, 2011 by homiewes Quote My youtube channel, please subscribehttp://www.youtube.com/ballinblaza
kirill007 Posted July 3, 2011 Report Posted July 3, 2011 1100watt isn't smart to put to the SA's. It's too much . And you need a fourchannel to maximize power for the 4 voicecoils... lolz just kidding, mono-amp, easier to wire, cheaper. Quote Thinking is the root of all problems... You ALWAYS get what you pay for.
JEMT8 Posted July 3, 2011 Report Posted July 3, 2011 I'd go with the aq1200d provided they are d4 or find a used saz1500d. Quote formerly known as Jaylor Swift
homiewes Posted July 3, 2011 Report Posted July 3, 2011 (edited) ewww.. used amp? ^^ Edited July 3, 2011 by homiewes Quote My youtube channel, please subscribehttp://www.youtube.com/ballinblaza
kam311 Posted July 3, 2011 Report Posted July 3, 2011 Look at db-r.com for refurbished sundown amps for cheap! Or look at crescendo Quote so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
JEMT8 Posted July 3, 2011 Report Posted July 3, 2011 ewww.. used amp? ^^ One man's trash is another man's treasure. Quote formerly known as Jaylor Swift
kam311 Posted July 3, 2011 Report Posted July 3, 2011 I'd take a used sundown over most new amps that people see... Can't be too proud if you don't have the funds man Quote so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
