you cant wire them 2 d2 subs to one ohm, you can wire 2 d4 to a one ohm load and i would go with a the aq2200 u can usually find them used for around 300 just be careful on the gains get the smd dd-1 or a oscope to set ur gains
Edited by g6ryder
www.wooferwarehouse.com
you cant wire them 2 d2 subs to one ohm, you can wire 2 d4 to a ohm load and i would go with a the aq2200 u can usually find them used for around 300
Not sure how the SA-12"s will take 1100 rms each, but that's just cause I've never ran em. But OP, like he said, you would need two d4 ohm subs to get a 1 ohm load.
:rofl:
:wub: N8.
No homo...unless you want there to be. :orly3::ehh:
The audioque amps have a clip light to reassure you when bumping them hard.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
1100watt isn't smart to put to the SA's. It's too much .
And you need a fourchannel to maximize power for the 4 voicecoils...
lolz just kidding, mono-amp, easier to wire, cheaper.
Look at db-r.com for refurbished sundown amps for cheap! Or look at crescendo
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
I'd take a used sundown over most new amps that people see... Can't be too proud if you don't have the funds man
so far...
  • Who's Online   0 Members, 0 Anonymous, 2146 Guests (See full list)
