So my RCA broke off and the stem got stuck inside the amp. I tried a dwell screw like many have told me Nd it failed. So I was just gonna use the other channels (3/4) but when I hooked it up it went right into protect. So what do I do ?!
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Shit man, I wish I could help you on that one =\
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
I tried, there's no access to the RCA in this amp
Team Subsonic Lows
Have you tried using a magnet to draw the stem out?
Try pressing some chewing gum around it, then see if that can pull it out. If not, take a q-tip, cut off one of the ends so you only have the shaft part, put a TINY amount of super glue on it, press it to the rca stem, blow on it + count to 30 for it to dry, then pull it out.
Good luck with it.
Just as a side question: How did you manage to break the end off an RCA cable?
I have no idea, it just fell out so I tried to plug it in & saw it.
Team Subsonic Lows
