Supercharged DCs Posted July 6, 2011 Report Posted July 6, 2011 Chances are it will make it quieter if you are sealing them in the trunk. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
BJD3 Posted July 6, 2011 Report Posted July 6, 2011 My question is will sealin the trunk off from the cab make it louder if my subs are not at all in the cab The easy answer is the most correct one. It depends. Try it and find out. Quote Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
IH8PunkRok Posted July 6, 2011 Report Posted July 6, 2011 Chances are it will make it quieter if you are sealing them in the trunk. not even chances. if the subs and port are not facing into the cab sealing it off WILL make it quieter Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Supercharged DCs Posted July 6, 2011 Report Posted July 6, 2011 Chances are it will make it quieter if you are sealing them in the trunk. not even chances. if the subs and port are not facing into the cab sealing it off WILL make it quieter I've never messed with trunk cars, so even though logic and common sense tells me that it will be quieter, I didn't want to give him a definite answer. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
IH8PunkRok Posted July 6, 2011 Report Posted July 6, 2011 well i am giving a definite answer Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
STEvil Posted July 7, 2011 Report Posted July 7, 2011 It will be quieter. In a trunk car the loudest unsealed is 90% of the time subs back and port back. Sealed (very well sealed) performs best with subs forward and port forward (or up through rear deck). If you dont seal everything very very well, it wont get louder. Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
