2011 Chevy Tahoe, 10k watts, 4 Fi BTL 15s, 4 DC Power alts!
So I still have a bunch of questions after getting the alts. I emailed Kyle and am awaiting a response, maybe you guys know the answers:
1. The relay has a long fused red wire and a white wire coming from it. I assume the red wire goes to a free ignition switched slot in the fuse box, and the white wire to ground?
2. Each of the three connectors has a red wire and a blue wire. Where do I attach these?
3. Any tips on routing the new belt? I assume it's important to get as much "coverage" around each pulley as possible? Is there a rule of thumb for how much of each pulley I should cover in order to avoid slippage (40%, 60%, etc.)?
4. If I wanted to run a ground wire to an alt, where do I attach it?
i would assume thats what the red fused wire and the white wire are for, id wait and get a 100 % for sure answer from kyle though
as for ground wires, sine the alts dont have direct ground studs on them, best place would be somewhere along the alt bracket, cleand and sanded down to bare metal of course
thats all i can help with out of those
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Belt routing from left to right: under the top left most idlers pulley, over the top alternator, under the right top most idlers pulley, around right most alternator, over bottom right idler pulley, under bottom alternator, up and over to the left of left bottom idler pulley, wrap through stock pulley system as usual, done.
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
I can't wait to see how you do the doors, shit I can't wait to see everything, so much more interesting since we have the same truck :popcorn:
Run a ground to each alt mounting bolt, just one off each alt on the back side of the alt(s). THAT IS THE BEST SPOT!!!!
How long is the belt you have to run these? I can tell you if it will slip or not, basically anything over 118 inch is gonna slip unless you have two tensioners.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
That top alt should be ok, if u have issues you should be able to lower the first idler pulley down the bracket a bit by re drilling a hole lower, your belt would need to be longer
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
Was nice meeting you yesterday, im tuned in to your build. like i stated yesterday and im sure you already know. box design is the most important part of your build imo. If you need suggestions ill help you out. It also depends on how loud you want it. If you want low 5os or mid 50s :clapping:
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
alright you got all the deadening done time to get started on the box. :popcorn:
Gonna be a while yet, heh. Big question now is what order I do what remains to be done. I'm thinking this:
1. Get Alpine head-unit installed plus the 5 billion things that attach to it (Sirius, rear camera, etc.)
2. Build battery rack, install batteries front-and-back, install alts, run 0-gauge, burn down the truck.
3. Build amp rack, install amps, hook them up. Burn down the truck.
4. Simultaneously install components and build sub box. Switch between the two to keep my mind fresh. Kill myself with fiberglass fumes.
Easy 3 months remaining on this build.
If i were you my order would be 1234 hahahaha minus burning down the truck and dying
TEAM DC
Everything is a 150 on th earometer
Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw.
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
after reading through this build I saw one thing that I could help with lol!
the wind noise from the window can be taken care of.. I have no personal experience with it but after reading on the TahoeYukonForum there were a couple members that discussed using a double wide weatherstrip and it worked wonders at getting rid of wind noise
night and day difference
I could never find one when I had my Tahoe but it was always on my list to-do
hope that helps :drinks:
keep up the good work!!
Wouldnt be thehoe92 without teh purple
