Ok so when i upgrade my system im planning on having either 1 audio que 1200D (3 x 40 amp fuses) or either 1 audioque 2200D (external fuse rating of 200) and i was wondering would a --Power Bastards Fitzall High Output Alternator Total Output: 220+ AMPS Idle Output: 110+ AMPS Full Output at 1200 RPM--- Be enough to power the 2200 watt system or the 1200 watt system atleast? I just want to make sure that i give my amp the correct amount of power and Ive found it difficult to figure out what type or how big of a alternator i would need if any, and this is the only alternator that i could find that "might" even fit my 1999 saturn sl1 1.9L |4 . So can anyone help me out here and give me a opinion?
That alternator and a good battery should power either amplifier, but if your looking to power both I'd suggest a couple of large AGM batteries.
thanks ill probably end up running the 2200 and hdc3's now.
im running a AQ2200D @ 1 ohm on my Stock 160 amp alt and 1 D3400 and a stock battery, the amp is powered off the D3400 though, with very little voltage drop at idle.
if you got that Alt, and the Biggest XS power Battery you can fit under the hood with the Big three in 1/0, it should power it nicely
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
thank you for the input
I had a setup very similar to this and i went the cheaper route and started out with a big xs power battery under my hood and then i did the big-3 upgrade and it worked great for up to 2000w rms. Then i had voltage drop and got a mechman alt and it fixed everything. I always recommend to get as big of a battery as you can fit under your hood, perform the big-3, and then when you can afford it or if your voltage drop is bad get a high output alternator.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
yea i figured that since my voltage dropped bad with my old cheap system ( ran only a mtx thunder 500 2 chan) and it would drop to 13.1 when the bass hit hard, i figured that it was safe to say ill need a h/o alt no matter what, man all this stuff cost serious $ :( lol
id becareful with the power bastards. twisted child bought one of their universal alts and it didn't fit his hundi. you could contact dc power or mech man about a custom alternator. and you should get a couple of agm batteries to help maintain voltage
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
i did contact dc power but have yet to recieve a reply. ( i work 2nd so i emailed them)
  • Who's Online   0 Members, 0 Anonymous, 1599 Guests (See full list)
