put your box dimensions into torres calculator then for example enter 10 for height and 3 for width and then enter different lengths until you reach your desired tuning.
Thank you for the tip
Edited by jmilch
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
bend the port? That's pretty simple...
I know
Edited by jmilch
I just put it into Torres. He's right, the lowest possible tuning according to Torres is 51" long and a 35hz tuning. Then it starts to go back up
Edit: I used a 15.5x2.5 port area
Edited by DRauck
2011 Honda CR-Z Mugen
12" Kicker SoloX Subwoofer
Rockford Fosgate t20001bd
Pioneer AVIC-X930BT Head Unit
Build Log
I cant reach 32 hz that way.... ive been sittin here with torres.
then just make the port slightly smaller until you can reach 32 Hz
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
With 16sqin per cube, I've noticed you can achieve a low tuning between 20" and 30" long. I would try and work on something for you, but again, no computer. Go into Torres, try and get 16sqin per cube of port area, make sure you have 3 common walls entered into the program, and try 20"+ until you find the tuning you want.
OP, do a 15.5x1.75 (should be the height of your box -1.5 of MDF) and make it 26 inches long. Does that work for you? It's 2.26ft^3 net and 32.2hz
Edit: Or you can go 15.5x2 and make it 33 inches long. But then your box is 2.05ft^3
Edited by DRauck
Build Log
Sorry the box is .75 red oak ply. I think that matters. I am going to mess with 15.5 x2
I may end up just doing a aeroport if I can't get decent tuning with a slot...
Ok guys so I used both torres box calc and the calc from precision sound (found here) and I decided to just go with aeroports.
But I am trying to figure out how many I need.
If I do 2 x 4" ports by a 25" length, I can tune to 32 hz. Does this sound like its in the ballpark?
OR
If I do a slot port, I came up with 3" x 9" x 29"
That gets me 13"^2 per foot, and 31.5 hz tuning.
Does that sound about right?
Edited by jmilch
OR
Bump
Can someone verify before I start cutting?
OR
Either one of those will work fine
Build Log
  • Who's Online   0 Members, 0 Anonymous, 15568 Guests (See full list)
