bassrace Posted July 27, 2011 Report Posted July 27, 2011 Well i have a pyle hu (i know) and my sub jacks (or rcas) were pinched so i cut them i didnt want a fire due to wires touching. So my question is, there is a white wire, a red wire and 2 wires thats not in a jacket (which i assume is the - wires). and in the new rcas i will be putting in their is a red wire a blue wire, a red wire with a black stripe, a blue wire with a black stripe and the a single wire not in the jacket, where does this wire go/do? Thanks in advance 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
BassMunky Posted July 27, 2011 Report Posted July 27, 2011 noooooooooooo Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
6berry Posted July 27, 2011 Report Posted July 27, 2011 i would recommend just getting a new headunit. pyle makes horrible products and you'll probably get even worse distortion from connecting rcas like that 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
bassrace Posted July 27, 2011 Author Report Posted July 27, 2011 noooooooooooo ?? To the pyle?? 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
bassrace Posted July 27, 2011 Author Report Posted July 27, 2011 i would recommend just getting a new headunit. pyle makes horrible products and you'll probably get even worse distortion from connecting rcas like that Sry dude but im just fixing it its a dvd screen and its getting sold. That being said I need help not ppl tryn to show their marketing skills. 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
Superjay Posted July 27, 2011 Report Posted July 27, 2011 I'm going to disagree with everyone here. I've been doing this MANY many years, and this is where I know better, plain and simple. Solder the connection, and make sure it's wrapped in TIGHT 3M electrical tape, or heat shrink. RCA plugs catch more noise than a solder joint, so hardwiring is ALWAYS a better solution. the only reason we typically stick to the plugs is that it's easier for the average person to connect...and nobody knows how to solder anymore. in your RCA's where you have a red and red with black, those are your signal wires for one side. use one for positive and one for negative. those wires are a twisted pair to reject noise so you'll have to test the other end to see which is which...I'm going to take a wild stab at it and say the one with black is the negative. the single wire is for grounding the head unit chassis to the amplifier chassis...use it. Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
bassrace Posted July 27, 2011 Author Report Posted July 27, 2011 I'm going to disagree with everyone here. I've been doing this MANY many years, and this is where I know better, plain and simple. Solder the connection, and make sure it's wrapped in TIGHT 3M electrical tape, or heat shrink. RCA plugs catch more noise than a solder joint, so hardwiring is ALWAYS a better solution. the only reason we typically stick to the plugs is that it's easier for the average person to connect...and nobody knows how to solder anymore. in your RCA's where you have a red and red with black, those are your signal wires for one side. use one for positive and one for negative. those wires are a twisted pair to reject noise so you'll have to test the other end to see which is which...I'm going to take a wild stab at it and say the one with black is the negative. the single wire is for grounding the head unit chassis to the amplifier chassis...use it. Thanks alot. But my hu only has 4 wires and the new monster cable rcas have the 5th wire any suggestions? Should i just leave the 5th wire alone? Your help is appreciated 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
Superjay Posted July 28, 2011 Report Posted July 28, 2011 that 5th wire is a ground wire. you connect it to the radio chassis and the amp ground to bring the ground potential of both to the same level...helps prevent ground loop feedback. Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
