SMD Member's SPL Scores (Charts Up)
Hotdog
Remember if you are not seeing the updates try refreshing the page. When I update I use the same name for the jpg so the old one may be stored in your internet cache.
I am putting together a Chart for SMD members that will list the top three SPL wise in each category. This will also help determine which vehicles in each category tend to get louder.
Here is what I need
Name: if you don't list a name I will just use your user name
Vehicle type: Compact / Coupe / Sedan / Van / Truck / SUV
Vehicle: Make / Model
What RMS range are you in: 0-1000rms / 1001-2000rms / 2001-3000rms / 3001-4000rms / 4000+ rms
Amp / Amps Brand: Just the amp for your subs
Certified Score: Show picture or Video proof from certified event and list event type (DBdrag / Meca / USACI / etc.. etc..)
UN-certified score: Video proof of your car metering
Meter Location: Dash / Kick / Head rest (no port scores)
Peak Frequency:
Anyway I am going to give this a shot so fire away with the info :)
p.s. TL Scores only
98 acura integra hatchback
3 DC audio lvl 5 18s
1 stetsom 7k2d
6000w clamped, at 2 ohms at 10v
155.2 at 35hz at the headrest
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
1 stetsom 7k2d
Dont forget to list RMS range.. however I know your over 4000rms :)
1 stetsom 7k2d
fixed, better? :)
Team DC Audio
2004 suburban
4 massive audio db8000's (clamped 12400)
2 aa mayhem 18's stock 5spider
Ported box 11.6 after
155.0 meca at headrest 41hz
153.8 meca on 320amps of fusing street4
154.3 sealed drag legal
Same amps but using 2 aa mayhem 12's
152.7 meca on 320amps of fusing
153.2 meca no fuse
153.4 drag legal
40hz box is 4.6 after ported
Same amps but 2 aa mayhem 15's
Box is 7.9 after ported
154.3 meca on 320 amps of fusing
154.6 no fuse
Single mayhem 18
4th order 3/6.9
On a memphis 4kw
150.9 meca on 120amps of fuse
151.2 250amp fuse meca
43hz
Ill add more later.
Name:
Mario B
Vehicle type:
Sedan
2004 Chrysler Sebring
4000+ rms
Sub Amp / Amps Brand:
2 Kicker ZX2500.1
149.2 Ceritied DBdrag
150.2
Meter Location:
Dash
Peak Frequency:
57Htz
Will get the pics up later tonight
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
I put this together tomorrow morning.
There will be 6 charts 1 for each vehicle type and then each vehicle type will be broke down in to there RMS ranges
example:
Car Type | Make/Model | RMS Range | Sub Amp | Certified Score | UN-Certified Score | Meter Location | Wall / Below Window Line
Will look like this but cleaner I will use excel so it is manageable and I will just take screen shots and post them.
I do not need to know how many sub's or type of sub's you have that part is really irrelevant since all we are looking for is power range / score / Vehilcle. I guess I could break it down to wall setup and below window line setup also since that part would be relevant.
dc98hoe
vehicle type-suv
vehicle-98 chevy tahoe
Rms range-4000+
sub amps/brand-2ddm4s
155.6 dbdrag
un certified- will post vid asap
meter location- 155.2 is headrest meca style,155.6 is dbdrag on the glass
peak freq-38hz
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Update.. Charts are made just need more scores.
I tried to make it so it is not so cluttered.
If there are any error's just post and let me know.
For right now I am only posting top three scores in each category but may expand later.
