If it's going to be 1 common wall, my numbers won't work out. Will it be from top to bottom in the center?
Was going to do right down the center in the back, and in the center toward the sub. So L shaped, down the middle of the back.
BUT, after punching some more numbers, I cam up with this design...
Going to go down the left side in the back, and just use the length of the box to my advantage. The port will be off center, but if it allows me to do what I want, it will be fine.
So I came up with...
2.5 x 10 x 30 = 30hz tuning, and 12.89"^2 port area
What do you think?
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
I don't have access to Winisd at the moment, so I can't see how the box will work and I don't want to give you an answer that I'm not certain of. Someone else should be able to check the design for you and see how it will react :)
I moved from winISD to just using torrex now. winISD doesnt account for a few things, and it seems the curves are always a bit off.
I am going to sketch it up, and post it to see if it should be good.
Then maybe RAM or someone can chime in
A single six inch (inside diameter) round port should work for a round port, otherwise I'd try about 32-40 square inches of slot. Probably shooting for right at 2 cubes net. Just an off the top of my head estimate anyway.
I looked up the price of aeroport and pvc 6", both are our of the question.
So I am back to trying to figure out a slot port for the design.
The outer dimensions are 17x23x16, and its .75" wood.
If PVC is too expensive, look into sono tubes or concrete formers. You can usually get those pretty cheap if you wanted to go with a round port.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Yeah PVC is ridiculously priced right now lol
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
