just got a new muffler installed on my 03 v10 and moved the exhuast forward and added a 6" tip...the muffler is a custom designed muffler from mufflerman in O.C. I got it done today and it seems like I'm getting worse gas mileage then before(I had a gibson catback performance muffler)..could it be that the muffler isn't giving the engine the right back pressure? Or does it take a little bit for the engine to get used to a new muffler? Also it kind of smells weird..but idk if its because of the new muffler? And suggestions on what it could be?
BABYJUICE
I Dont think the engine will get used to it, if its not right call the company and tell them
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
I think it's the muffler. I have a feeling that it doesn't need to 'get used to it'. I guess see if it has gotten better, or else call the manufacturer and let them know. also, see if it's a common occurrence..
Are the O2 sensor's connected?
Changing mufflers will usually have little impact on gas mileage but if other changes were made like removing the cat from the system than there is you problem.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I did some reading on a Ram forum and it seems these motors do like some back pressure. Most issues were power related, so I don't know about mileage. But most of these guys, even with engine mods, are running only 2.5-3" pipes back to 4" tips. So, pipe diameter could be it, or O2's like Skullz suggested.
SMD Super Seller
My Feedback Thread
This could be a potential area to look into.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 2139 Guests (See full list)
