How many of you are running amps like DC, AQ, Crescendo, Sundown or the like wired to half ohm without problems? I know that there are some on here. Where yall at and have you had problems doing so or not?
2000 zx2: Rebuild with 8 12s on a 10k underway!!
MY BUILD LOG
This guy is <<<<~~~~ no problems none! Dc3.5k
="Impact"]
pioneer 4200 dvd
4 sets aa carbon mids
2 sets rockford power t1 tweeters
rockford power t400.4
rockford power 4inch
DC 175.4 DC 3.5k (soon to be 2)
2 DC XL 15s
The artist formally known as willie3719
i have had my saz3500d wired to .45-.5 (changed with boxes) since march and have had not a single issue.. amp hasnt protected once, nor has my amp seen below 13v.. never even gets moderately warm
Edited by BeAlLsTaR13
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
I was for over 2 years with IA 40.1s.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Im running 2 dd m4s strapped at .7 so .35 each daily sometimes get protect issues on music below 30hz full tilt I think its vibration cause my amps are mounted on the side of box and its usually around 154dbs plus when it does it but the amps come right out of protect:-)
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
And it is very loud.
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
Because Person A is able to run his equipment at .5 ohms (whether ignorantly or not) does not mean Person B will be able to. Just stating.
i used to have my old aq3500d.1 @.5 before,
with zero problems,
but it did use to get warm
even doe i had 4 xs power d3100s and a d1200 under the hood with the 320 mechman
took things like a champ
right now i have my dc 9k @ 3.5,same electrical except more 0g runs and upgraded the d1200
to a d2400
so far zero problems as well,hasnt gone to protect,doesnt get hot,sometimes i feel the amp
aint even connected lol
and voltage doesnt go below 13.6
when i dont rev it sees 12.9,sometimes 12.8
like team bass hz said,it depends man,not all ppl can pull it off,
you just need some cool electrical to keep things stable,but than again
wiring that high can most of the time be unhealthy for your equipment,just becareful
:good:
gdluck
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
i ran my saz1500s at .5 strapped daily. i could put them into protect or burn the fuses but that was not all that common. ran two crescendo 3ks at .5ohm daily, no problems.
but i kept my voltage at a safe level and i had my amps in closed amp racks with two fans on each amp to keep them cool.
Edited by skittlesRgood
