Alright, little update. I just had my truck metered today (thanks to my boys at Underground Autosound) Here are my scores with everything sealed up.
146.6 db on the dash
148.1 db in the kick
151.7 db next to the port of the box
Peak freq on the termlab was 49Hz
Peak freq from my ears seems to be like 35-38Hz
This was with the windows rolled up, doors shut, tailgate shut as well. I played the song Its Doja from Ren Da Heat Monsta and got a 135 on the termlab.
I also had the bassboost all the way off on the db8000's since i didnt want to do any of that crap anymore and was playing with absolutely no distortion.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
  • 3 weeks later...
Another update, since i somehow managed to smoke 3 fets on one of my db8000's and crack another 2 of them in half i am ditching the db8000's and getting a DC Audio 5.0k amp to run my SMD. It should be a little more promising to get around another 1k of power going to the sub and keep the amps matched for those who are picky about it. I am getting that amp Friday this week and plan to install it asap so ill keep you posted when it gets here and gets in.
Ill buy the burnt db8000 off ya
ygpm^
Thats what im hoping, its only 1k+ of power for my smd but it should really get it kicking more. Im also going to see if i can find time to get a dedicated ground wire for my truck instead of grounding it through my frame to help support the 5k amp even though i didnt have crap for voltage drop.
Alright, little update. I finally got around to installing my DC 5.0k and i clamped it today. Here are the results:
I am running just one of these amps up to my single AA SMD 18" dual 1 ohm sub in a 5.5 cubic foot box tuned to 30Hz. The test was made with my sub wired in parallel to achieve a nominal impedance of .5 ohms and the battery voltage was 13.7v. The clamp results are as follows:
30Hz tone: 1454.583 watts at 1.41 ohms
35Hz tone: 2525.54 watts at 1.63 ohms
40Hz tone: 4061.64 watts at 1.37 ohms
45Hz tone: 5291.84 watts at .976 ohms
50Hz tone: 5161.32 watts at .971 ohms
55Hz tone: 5215.0 watts at .939 ohms
60Hz tone: 4778.4 watts at .912 ohms
Average impedance rise and wattage from 30-60Hz: 4096.76 watts at 1.173 ohms
Overall i am really satisfied with my DC 5.0k even though the low end tones have less power than my old amp (two Massive Audio DB8000's strapped at .5 ohms nominal) but the higher notes have a lot more power and the clarity of my 5.0k is amazing. With my DB8000's the clarity was alright but the bass was really punchy, with the 5.0k the bass seems to have a slower run off and a more even tone. Plus with this amp, it doesnt get warm at all when my engine is running, if i bump the amp at around half volume with the truck off for a total of 3 hours (i sit in the parking lot at class until my next night class starts) only one half of the amp is warm but its not enough to burn you like my old DB8000's.
Thats what i was really thinking because if it was the amp it would have reacted differently with the amps i got from you and the dc amp. Either way im really not concerned about it because for everyone including myself who listens to it at low freqs you would swear its getting the full 5kw of power so it really caught me by suprise when i saw it was only putting out 1454 watts.
