kam311 Posted August 11, 2011 Report Posted August 11, 2011 Oh yeah man I freakin love those little 8's! I'm waiting for someone thats wants a little system with a single 8 soon so I can make them order one haha so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
BJD3 Posted August 11, 2011 Report Posted August 11, 2011 The 8's don't have the same motor i don't think man, the 10's 12's and 15's do tho. The 8 is rated for 400 watts. I could be wrong tho. What I do know is that the sa motor is 7in diameter 3" tall with 2 1" slugs... Fuggin beasts man!!!!! IIRC, its the same motor, but the 8's have less excursion than the 12s. So they rate them lower. From what I'm given to understand, they will fail mechanically long before they do because of the coil not being able to take the power. Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
97SSBlazer Posted August 11, 2011 Report Posted August 11, 2011 Ported box, 2.0 cubic feet each. ALPINE TYPE R's I run 5 12's in my Impala and 1 12 in my Neon... lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz. -= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash Subs: 2 T1 12's Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:) 2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/ 2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/
kam311 Posted August 11, 2011 Report Posted August 11, 2011 The 8's don't have the same motor i don't think man, the 10's 12's and 15's do tho. The 8 is rated for 400 watts. I could be wrong tho. What I do know is that the sa motor is 7in diameter 3" tall with 2 1" slugs... Fuggin beasts man!!!!! IIRC, its the same motor, but the 8's have less excursion than the 12s. So they rate them lower. From what I'm given to understand, they will fail mechanically long before they do because of the coil not being able to take the power. Are you saying that the 8's fail before the 12's? so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
kam311 Posted August 11, 2011 Report Posted August 11, 2011 Ported box, 2.0 cubic feet each. ALPINE TYPE R's I run 5 12's in my Impala and 1 12 in my Neon... Okay I liked my type r's but the other subs mentioned in this thread would shit on them lol so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
EBW Posted August 11, 2011 Report Posted August 11, 2011 They have the 2" coil don't they? Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm
kam311 Posted August 11, 2011 Report Posted August 11, 2011 They have the 2" coil don't they? What do? Lol so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
BJD3 Posted August 11, 2011 Report Posted August 11, 2011 The 8's don't have the same motor i don't think man, the 10's 12's and 15's do tho. The 8 is rated for 400 watts. I could be wrong tho. What I do know is that the sa motor is 7in diameter 3" tall with 2 1" slugs... Fuggin beasts man!!!!! IIRC, its the same motor, but the 8's have less excursion than the 12s. So they rate them lower. From what I'm given to understand, they will fail mechanically long before they do because of the coil not being able to take the power. Are you saying that the 8's fail before the 12's? If you put them in a large box with a lot of power, yes. Then again, that's any woofer. Point was the reason they downrated the SA-8. http://www.stevemeadedesigns.com/board/topic/73681-sa-8-power-vs-box-size/ Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
kam311 Posted August 11, 2011 Report Posted August 11, 2011 The 8's don't have the same motor i don't think man, the 10's 12's and 15's do tho. The 8 is rated for 400 watts. I could be wrong tho. What I do know is that the sa motor is 7in diameter 3" tall with 2 1" slugs... Fuggin beasts man!!!!! IIRC, its the same motor, but the 8's have less excursion than the 12s. So they rate them lower. From what I'm given to understand, they will fail mechanically long before they do because of the coil not being able to take the power. Are you saying that the 8's fail before the 12's? If you put them in a large box with a lot of power, yes. Then again, that's any woofer. Point was the reason they downrated the SA-8. http://www.stevemeadedesigns.com/board/topic/73681-sa-8-power-vs-box-size/ Oh alright, well yeah it makes sense! Bit they are beautiful still, and little beasts so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
EBW Posted August 11, 2011 Report Posted August 11, 2011 I was gonna do 4 sa8s in my blazer just went with 2 sa15s instead good amps are expensive and I'm no balla all the nice shit I get goes in customer cars :/ oh well I'm gonna get me a 2.5k amp soon then 150 budget build here I come Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm
