TheInfamousImpala Posted August 11, 2011 Report Posted August 11, 2011 Last Night my amp all of a sudden started flickering back and forth from protect to power.....I checked all connections and even changed the fuses....Im Out Of Options ?????......Anyone know what that could be????? 2003 Impala LS "Under Reconstruction"
EBW Posted August 11, 2011 Report Posted August 11, 2011 Is it still doing it? Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm
ingramcaraudio Posted August 11, 2011 Report Posted August 11, 2011 Highs amp or sub amp and what's the voltage of the amp if you've checked it. If not that's a key thing to do. Facebookhttp://www.facebook.com/#!/pages/Farmville-VA/Rockwell-Audio/103036213076623?ref=ts
EBW Posted August 11, 2011 Report Posted August 11, 2011 I was just going to ask if you were running a bigger alt and extra batt? Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm
Team_DC-Derrick Posted August 11, 2011 Report Posted August 11, 2011 check the remote wire.. check the speaker wires and make sure none of them are touching each other, check the power/ground/remote wires to make sure there is NO wires touching each other... after that, i would venture to say check the wires up front. The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
252chevyboyz Posted August 11, 2011 Report Posted August 11, 2011 Good questions ingram. Also one other question is where is the ground located and is there any paint on the metal where it is connected? Just a thought what class amp? - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log
TheInfamousImpala Posted August 11, 2011 Author Report Posted August 11, 2011 Is it still doing it? Yes Sir 2003 Impala LS "Under Reconstruction"
TheInfamousImpala Posted August 11, 2011 Author Report Posted August 11, 2011 Highs amp or sub amp and what's the voltage of the amp if you've checked it. If not that's a key thing to do. My Sub Amp and Im gettinn between 13.8 to 14 2003 Impala LS "Under Reconstruction"
D-train-13k Posted August 11, 2011 Report Posted August 11, 2011 i would check your charging system as well. you might be going over its max voltage. as well check all the other things stated lol Edit: saw the charging post. have you opened up your amp to make sure nothing is bouncing with your subs vibration? you could have broken something and the vibrations are making the contact come loose The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
ingramcaraudio Posted August 11, 2011 Report Posted August 11, 2011 Will it come back on by itself or do you need to turn the radio on and off to get it to turn back on? Facebookhttp://www.facebook.com/#!/pages/Farmville-VA/Rockwell-Audio/103036213076623?ref=ts
