how do i change lowpass? im confused? is that the gain on the amp..... im sooryy for noob question but i havent done much with amplifiers thanks for the help
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
wow... ok.... there will be a knob on the side of the 2200 that will say subsonic, use a flat head screw driver and adjust it to a little under your box tuning. Then, about 3 things to the right, there will be a knob with LPF over it, adjust it to 70-80hz. theses "knobs" are where the bass remote plugs into the amp.
try reading the amps manual. :shrug:
Edited by ChevyBoy95
Looking at your amp from left to right is the input, next is the gain, next is the subsonic which is set just below box tuning, next is bass boost which is set to 0, next is the remote plug, next is low pass filter which you'll set to the 12 o clock position or there abouts which should be around 81hz or so, next is slave/master switch and finally output for slave to strap amps.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
lol i know that ha... so i got subsonic right... ihave the LPF set their =) lol
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
and mine vibrates on output master, but i dont want it on that lol im not strapping
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
If the amp is anything like the ones I'ved used, you would want it set to master and not slave.
ok so i do want it in the master output position?..il post a picture of my gains here quick.. give me a sec
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
  • Who's Online   0 Members, 0 Anonymous, 3366 Guests (See full list)
