Hello everyone!
In my next upcoming build, im going to be using a plexiglass window in my build. But i have a question...I was going to use 4 pieces of allthread through the middle of the box for bracing. N8ball suggested that i use plexi rods for bracing instead which would look 1000x better in my opinion. I have found proper adhesive that would bond the plexi rods to the window, but i am concerned about how to adhere it to the wood on the bottom of the box. i feel that no matter how good of a glue bond that i can get, it would seem easy to peel off the top layer of wood that the plexi rod would be attached to. SO, my question would be....do you guys have any suggestions on a good way to mount/adhere the plexi rods to the wood.
This is a picture of the sketchup design that will better explain what im planning on doing. you can see the 4 peices of allthread that would be in the center.
The top part will be 3/4 inch plexiglass
You can also check out the build log so far. its the first one in the sig. Leave me some input!
to attach the edges to the wood you could use the adhesive and drill and countersink holes and use screw to hold it as well.
one thing it 3/4" might be too thin for how large of a piece you are using but i dont personally have experience with plexiglass
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
i think you should be able to use screws if u pre drill and be careful like 6berry not much experience with plexiglass but making a money clip in shop class lol but the design looks awesome man i like it but personally think you should be fine using a wood screw if u pre drill
2 12ks and i dont know what to do
build in the works!
I love the design, i would think screwing would be good and glue, just make sure it dries all the way then if you really want you can do some fleece and resin just as a extra and paint it the color of the box
system:
changes way to much...
It would also look cool if you sand it and make it have a flared look into the wood
system:
i know this isnt your question but is the bottom of that box open? just from the pic it looks like its sealed on bottom, sealed on top.
when i made plexi windows i used screws into the wood with washers pinching the plexi and caulking all around the joint. but that didnt need to hold any pressure because it was an amp rack, so... :pardon:
Edited by skittlesRgood
Use a router and route out an area the size of the rod so it's countersunk into the wood, then predrill and screw it through the bottom and you will be good to go
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
yes. the bottom of the box is open. it is a downfiring box...with the subs "inverted" if you will. Yeah thats my only trouble is that it needs to be solid as hell. the only thing i could think to do would be to tap a bolt into the rod and through the wood
well ive found that you can tap plexi but its risky due to breakage. my concern is if if will be strong enough to actually act as a brace instead of just decoration
  • Who's Online   0 Members, 0 Anonymous, 12380 Guests (See full list)
