LoudNLow931 Posted August 16, 2011 Report Posted August 16, 2011 Whats the subsonic at? If its set above 40hz that could be your problem? 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
OrionStang Posted August 16, 2011 Report Posted August 16, 2011 Whats the subsonic at? If its set above 40hz that could be your problem? Shouldnt be on at all. SMD Super Seller My Feedback Thread
LoudNLow931 Posted August 16, 2011 Report Posted August 16, 2011 Whats the subsonic at? If its set above 40hz that could be your problem? Shouldnt be on at all. That's what im saying it should be as low as it can be. 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
BJD3 Posted August 16, 2011 Author Report Posted August 16, 2011 EDIT: Just realized it may help some if I state this is for the amplifier in my signature. A Digital Designs M1a. Are you playing the 40hz track and not the 1k? Yup. 40 Hz at -5 dB. I also went back to using just the RCAs and it detected a signal just as it should. Just a thought but did you plug them back in after doing the H/U? Definitely. I did that multiple times as a matter of fact. Whats the subsonic at? If its set above 40hz that could be your problem? Subsonic is all the way to the left at 10 Hz. EDIT: @OrionStang The subsonic has no way of turning it "off". The only way to "defeat" it is to put it at its least effective position. Gain could be wherever in the hell it wanted to be and I still got nothing. Bass boost is again at 0dB. The "Output Master/Input Slave" switch never moved, and is set to "Input Slave". For clarification, the switch isn't to tell the amplifier what it does per say, but to say what the third RCA jack corresponds to. It confused the living hell out of me when I first set this amplifier up. lol There are no other controls on this amp. Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
Robert8252 Posted August 16, 2011 Report Posted August 16, 2011 Put it on master 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
01 S-10 Posted August 16, 2011 Report Posted August 16, 2011 Did you try switching it to Output Master. I know you said it doesn't matter just trying to rule everything out Edit: the main amp should be on master, all of the amps that follow would be on slave TDH FTW !!!
BJD3 Posted August 16, 2011 Author Report Posted August 16, 2011 Put it on master I can try it, but I honestly don't think that's the issue. Like on this amp here, there is a line pointing to the jack. Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
Team_DC-Derrick Posted August 16, 2011 Report Posted August 16, 2011 wait, i thought you tested the RCAs to see where the headunit was clipping at.. and then plugged the RCAs into the amp, and checked the amp at the speaker terminals... dunno if i read it wrong or what, but it sounded like you unplugged the RCAs and plugged the DD1 into the rca spot and got nothing... if so, you got that backwards LOL you need the RCAs in the amp, to test the amp, otherwise the amp wont get any signal to play something.. edit, i prob did read something wrong there, LOL im just really tired The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
OrionStang Posted August 16, 2011 Report Posted August 16, 2011 I think if its on slave, but its not a slave, it won't work. Try it, let us know. SMD Super Seller My Feedback Thread
