DC Sound Lab
NoFearX18 said:
trainman0978 said:
nick i hate u right now :drinks:
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Sweet bro and I charge my 14v batts at the same voltage 15.8 with no problems I found out when driving my steering sensor doesn't like above 15.8 long story but at comps I adj up to 16.8 and charge in between the only bad thing with 14v is it moved me into mod class in meca because your only allowed to use 12v for street classes. Want to see some numbers on this bish and moar vids please
Edited by dc98hoe
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
i see enough room for 2 more 18s..........
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
just 2? i see enough room for like 6 total, maybe even 8 LOL
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
baby steps D baby steps. :D
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Can the 12k's take 15.9 or do you run the risk of damage at 15.9? Just curious because as a word of warning some newer GM vehicles will start as high as 15.9. Mine starts between 15.7-15.9 on a regular basis.
Sorry to thread jack as well, but a 14v battery charges at what, 17volts almost? I thought the 12k was only 12v stable. Where does it protect? How can you run a 12v amp that is only stable up to like 16ish volts at higher? And if it is stable on a 16v system, it's normally stable on an 18v system. So why go 16v if 18v costs very little more and is just that much better? I'm not bashing or anything just curious if I'm missing something. :P
It will charge at 15v. As far as why to do 14 over 16 goes... Two reasons (that I can think of ATM)...
1) Many newer vehicles will run fine switched over to 14 which means you don't need to blow money on step downs.
2) Battery capacity is lower the higher voltage you go (in the same foot print).
Edited by UnderLoK
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
  • Who's Online   0 Members, 0 Anonymous, 2827 Guests (See full list)
