Fi 18/AQ3500
xxBeaudsxx
Alright guys, so the purchase is about to be finished, just need some help from anyone with experience for the FI 18"/AQ3500
So heres what im buying, and let me know if things will run smoothly, this is all going in a 2002 Blazer Xtreme
FI 18" (1 or 2ohm?)
AQ3500
KnuKoncepts Power/Ground
2x Kinetik HC2000 (one replacing main battery, other in the back)
Kicker RCA
DC Power HO Alt. 190 amp -140 idle
So I have quite a few questions.
Should i run 2 powers from the main battery, back to the 2nd battery, and 2 more from the 2nd battery into the amp(3500 has 2 inputs for power)..or should i run 1 power from the main battery, back to the 2nd batter, and then 2 from the 2nd battery into the amp.
As well as the ground..it has 2 spots for ground. Should i ground both of these 2 the same same spot...or should i ground them in different spots?
Will the 2 Hc2000 with the dc power ho alt be able to handle the power without volt drops?
And last but not least, anyone with experience with the Fi 18, what are some good box dimensions, and total cubic ft..im either looking to do sub up port back, or sub back port back, i prefer the sub back port back look. Not going for complete loudness if the way the sub faces makes a change in that.
Saw this was posted in the home theater section, was like ZOMG 4300w home theaterz lol. Must be the guy with the house shaking bass...
But in all seriousness, I highly doubt that the FI Q will be able to withstand that much power.
EDIT: Mus be tripping balls becaus of this big ass monster I'm chugging, I swear I saw you were going to use a FI Q a second ago, but now I don't see anything. So which FI woofer will you be putting the AQ3500 on?
personally i feel 3500 is way to much power for that Q.
:werd_msword:
But on another note, all you stated was FI 18"
witch one are you talking about? FI Q? SSD? BL? just wanna make sure
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
  • Who's Online   0 Members, 0 Anonymous, 1377 Guests (See full list)
