What clip light?
on the AQ gain knob..
OrionStang has a thread on this. I didn't really follow it though. I've experienced the same thing.
I think the clip light is just premature.
When I set my gains, I know the tone was clean, but the DD1 said I had no clipping, while the clip light said EVERYTHING was clipped.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
What clip light?
I think I saw that, I know my headunit is clean up to 34, and I know my gain is set right, and decaf music is clean
Guess ill just slam and cover that light haha
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
a good majority of music i mess with ends up -5db or louder... so you are clipping because you used a test tone that was quieter than the music you are playing
i see it being suggested to use -10db for subs alot, but as stated above there's plenty of music (not just mine) thats louder than that, so u will run the chance of clipping the amp anytime you play something louder than the test tone used. typically you see more people using -5db to -3db for more "safety"
Has anyone ran into this problem using a preamp? I couldn't get mine to clip on the fullrange or sub output using -5 or -10 should I be using the 0db track like the deck?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Yes use 0db. Gain overlap is set at the amplifier not the deck or the processor.
Helix P SIX DSP
Audiofrog GS10/GS60
Hertz HSV165XL (Rear Fill)
Do you have a gain pot on the back of your preamp ray?
What ac voltage out of the preamp are you getting?
Pots are all the way up will check ac voltage tommorrow its a arc audio i think its like 8v:
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
If your getting 8v out no need for anymore. Lol
Thats way more than enough.
I back mine down to 5.5-6volts. Plenty of input big guy
