HELP - Subs not loud
Hobbs155
Like this, then the two wires coming off, plug into the terminal on the box...or drill a hole, run the wire thru it and seal the hole up.
So I want to take the + and - from the one sub to the other and then to the terminals? Rather than my current setup where they both go the terminals from the subs.
Do you have the negative of one coil, connecting to the the negative of the other coil directly? Same with the positive or the coils...on both subs?
10501650_10203332501847103_1859383749711
Blown
I drew something up in paint quickly so you can see what i'm doing, lol
https://skydrive.live.com/?sc=photos&cid=f379b6a511559622#!/?cid=f379b6a511559622&sc=photos&uc=1&id=F379B6A511559622!192!cid=F379B6A511559622&id=F379B6A511559622!202&sc=photos
HU: Alpine CDA-9886 with Imprint Module
Fronts: Alpine SPR-60C
Rears: Alpine SPR-60
Amps: Alpine PDX4.150 and ICE Power 20000D
Subs: 1 x 15" Rockford T2D215
Big 3 Upgrade 0/1 AWG
2 Farad Cap
Wiring 2 AWG
120Amp ALT
How can he run them like that if thats for SVC not DVC?
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
You don't have to use both coils of a DVC sub. You can use one coil, but the RMS rating changes to around 40% or the DVC rating.
Hobbs, I'm not sure if that still has the same affect. I have never set it up like that. try it from sub to sub and see what it does. Doing the way you are makes me think you are running each sub parallel.
Like so,
Blown
Like so,
Thank you, i'm hopefully going to be able to put my ports in tonight and wire them up like that and see what i get from there. Thanx again for the advice.
Any advice on the ports?
2 Farad Cap
Wiring 2 AWG
120Amp ALT
Wat about a bad set of rca's??
That's a good point, I think I must try some others, what are the best ones to buy? I think I need better quality RCAs anyway.
2 Farad Cap
Wiring 2 AWG
120Amp ALT
  • Who's Online   1 Member, 0 Anonymous, 1230 Guests (See full list)
