sayhuh? Posted August 22, 2011 Report Posted August 22, 2011 Like this, then the two wires coming off, plug into the terminal on the box...or drill a hole, run the wire thru it and seal the hole up. So I want to take the + and - from the one sub to the other and then to the terminals? Rather than my current setup where they both go the terminals from the subs. Do you have the negative of one coil, connecting to the the negative of the other coil directly? Same with the positive or the coils...on both subs? Blown
sayhuh? Posted August 22, 2011 Report Posted August 22, 2011 This may be your problem. You might be running them like this You have to connect just like in the image. Then the wires coming out can connect to the box terminal. This is probably why you read 2 ohm Blown
Hobbs155 Posted August 22, 2011 Author Report Posted August 22, 2011 Do you have the negative of one coil, connecting to the the negative of the other coil directly? Same with the positive or the coils...on both subs? I drew something up in paint quickly so you can see what i'm doing, lol https://skydrive.live.com/?sc=photos&cid=f379b6a511559622#!/?cid=f379b6a511559622&sc=photos&uc=1&id=F379B6A511559622!192!cid=F379B6A511559622&id=F379B6A511559622!202&sc=photos HU: Alpine CDA-9886 with Imprint Module Fronts: Alpine SPR-60C Rears: Alpine SPR-60 Amps: Alpine PDX4.150 and ICE Power 20000D Subs: 1 x 15" Rockford T2D215 Big 3 Upgrade 0/1 AWG 2 Farad Cap Wiring 2 AWG 120Amp ALT
Baydestrian Posted August 22, 2011 Report Posted August 22, 2011 How can he run them like that if thats for SVC not DVC? 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
sayhuh? Posted August 22, 2011 Report Posted August 22, 2011 How can he run them like that if thats for SVC not DVC? You don't have to use both coils of a DVC sub. You can use one coil, but the RMS rating changes to around 40% or the DVC rating. Hobbs, I'm not sure if that still has the same affect. I have never set it up like that. try it from sub to sub and see what it does. Doing the way you are makes me think you are running each sub parallel. Like so, Blown
Hobbs155 Posted August 22, 2011 Author Report Posted August 22, 2011 How can he run them like that if thats for SVC not DVC? You don't have to use both coils of a DVC sub. You can use one coil, but the RMS rating changes to around 40% or the DVC rating. Hobbs, I'm not sure if that still has the same affect. I have never set it up like that. try it from sub to sub and see what it does. Doing the way you are makes me think you are running each sub parallel. Like so, Thank you, i'm hopefully going to be able to put my ports in tonight and wire them up like that and see what i get from there. Thanx again for the advice. Any advice on the ports? HU: Alpine CDA-9886 with Imprint Module Fronts: Alpine SPR-60C Rears: Alpine SPR-60 Amps: Alpine PDX4.150 and ICE Power 20000D Subs: 1 x 15" Rockford T2D215 Big 3 Upgrade 0/1 AWG 2 Farad Cap Wiring 2 AWG 120Amp ALT
sayhuh? Posted August 22, 2011 Report Posted August 22, 2011 Try the sub wiring first, then if you still aren't satisfied, ask for port help on here. I'm not the greatest by any means. I just have some knowledge lol. A lot I still dont know! Blown
TheyDontWantMusic Posted August 22, 2011 Report Posted August 22, 2011 I completely disagree. Look at ray doing a 152-153 with 2 mayhem 12s in a suburban IIRC. The size box he has for those things wouldnt fit in the trunk of a civic. So your logic is not correct. I didn't realise I had to clarify that it has to be a setup that will fit in both cars, I thought that was very obvious.
Hobbs155 Posted August 23, 2011 Author Report Posted August 23, 2011 Wat about a bad set of rca's?? That's a good point, I think I must try some others, what are the best ones to buy? I think I need better quality RCAs anyway. HU: Alpine CDA-9886 with Imprint Module Fronts: Alpine SPR-60C Rears: Alpine SPR-60 Amps: Alpine PDX4.150 and ICE Power 20000D Subs: 1 x 15" Rockford T2D215 Big 3 Upgrade 0/1 AWG 2 Farad Cap Wiring 2 AWG 120Amp ALT
