Depends on your budget and if you have any weight issues with your vehicle. Birch is going o be the more expensive but lighter option, About $45-$50 per sheet and about 60lbs and MDF will be your cheaper but heavier option, $25-$30 per sheet and about 90lbs. As for which is better that is pretty much just a matter of preference if nothing I said above applies to you.
Edited by CJ18
From what I'm given to understand, its a toss up. Birch is ligher, has less sawdust, and (IMO) looks better.
MDF is cheap. And works perfectly fine.
Don't know how they compare when you work with them except for the fact that MDF has a tendency to split if you don't predrill.
If I had to speculate, I'd think birch was a little healthier since you don't inhale crap tons of glues. But I have no fact to back that up. And I doubt you'd want to snort either one.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
here we go again, lol, comes down tp budget and preference really. most prefer mdf due to its cheaper and performs well, but birch gains about 30% in weight savings and usually about 40% more expensive.
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
Budget really isn't a issue but I've never tried birch and was curious if it had it's flaws
Around here birch is only about $10 more than MDF per 4x8' sheet. If you're bad at making clean cuts though it can fall apart. I prefer birch as I am in a small car, and the more weight I can save, the better. And if I remember correctly I think birch is actually stronger than MDF as well.
Edited by tonedeaf
I also heard that birch is stiffer than MDF which is better but how much better is unknown. It's not like your decidng between mdf and particle board. The next box I build I think I will spend the little xtra for the birch just to try it.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
I will be using birch for my next build due to the fact that I have already had to put helper springs on my truck to help deal with the extra weight of batteries and subs.
do you need it to be lighter?
dont "need" it to be lighter but would prefer lighter lol
  • Who's Online   0 Members, 0 Anonymous, 2296 Guests (See full list)
