CJs F150- 8/10..1 9k??? Nope....2!!!!
I had some blue CF vinyl left over from an old build that I figured I would try on the trim pieces between the subs. Its not bad but I think I am going to pull them and wrap them in black.
Before
After
Also put the final coat of body filler on the driver side door panel. I can now sand this down flat and it is ready to make the back panel for the door pods.
pretty dope man is that carbon fiber u put on the mdf easy to lay and work with, do u just staple it or use some sort of glue? also i would like to see a 10 inch carbon cap, i miss seen those
REFF'S
My link
EBAY
http://feedback.ebay...ck&myworld=true
I love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
I use spray glue and staple it on the back. It is pretty easy to work with. I am new to wrapping pieces and they have all turned out pretty good.
Driver door panel base started
I took blue painters tape and covered the door panel so I will be able to pop the pod off once it dries.
More trim panel work.
How to fix ugly sides you ask....
Step 1
Step 2
More driver door panel work. I will have the driver door roughed in and in fleece tonight.
Cutting out the inset speaker cutouts.
Before
After
Driver door pod fabrication.
Fiberglass base popped off door.
Pod trimmed down
Test fit
Pod off door for fleece
Fleeced and resined
Driver door waiting for finished pod
Looks great as always man. :good:
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
  • Who's Online   0 Members, 0 Anonymous, 1112 Guests (See full list)
