CJs F150- 8/10..1 9k??? Nope....2!!!!
hell yeah looking good Cody
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
damn, the plexi sides are sick! you gunna light up the inside with some leds?
Yup gonna use some white LEDs.
Well bro, from what pics you have posted already this thing will be solid and removable to.. Your attention to detail shows.. I have learned to, just take your time and dont rush it.. If you have one of those days where you dont feel like working on it dont.. Less mistakes when your more focused..
Jay
Everything will really start to come together tomorrow and look like it should. I only got 1 side wrapped and installed today but I did get the other side cut out and ready to get notched to fit the stepdown. Should be able to get the top and main bracing in tomorrow. So far I have 3 8 hour days in this with many more to come.
More done today.
Passenger side brackets installed and side mounted in truck.
Assembly of the driver side.
Outer piece is wrapped and inner piece is painted blue
2 1/2" sandwich pieces to go around the plexi.
Both sides now installed
Top installed
Bottom 45 started
That is all I have for now. The bottom 45 is drying and will be installed today. I may try and get the top side corners installed today as well.
Great job man.. Im digging the way you are building this so you can easily remove it if you need to..:yahoo:
Jay
The shell is 99% done.
I have 6 corners that do require so small glassing, 4 on the bottom 45 where I had to notch around the bolts and brackets and 2 on the top side corners. I will get that work done tomorrow and get the front baffle planned out. Kind of burnt out after 4 days of work on this thing so tomorrow will be a nice easy day. I should have the front baffles cut and installed on Sunday and have everything ready for the arrival of the subs and amps on Wednesday.
nice!! keep doing work man
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
Jay
Thanks. It should be alot easier to take out if I ever want to than it is to put in.
No real goals in mind other than to be painful to sit in. It will be put on the meter but it is not being built for the meter.
  • Who's Online   0 Members, 0 Anonymous, 877 Guests (See full list)
