im thinking about upgrading my amp from the Hifonics HFI 1000.d to an AQ1200. Im gonna be running 1 DC lvl 3 12" on it. I plan on getting another DC down the line and running both on that AQ1200. Would it be bad to go ahead and get the AQ amp and run just 1 DC on it? would i be risking putting too much power to it and blowing it? or should i just wait to get the other DC and the AQ at the same time? any advise would be Grrrrr8!
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
cheapo Legacy coaxes (just for now)
An AQ on 2 would be perfect. Get 4 ohm coils. Then you could get one, and wire it at 2 ohm. Then get another and wire it at 1 ohm
-98' Ford Expedition (Rest in Peace)
-AVH-P3300BT
-Crescendo BC5500
-4 18" DC m2 Level 3.
was thinking about wire each sub to 1OHM, then running the AQ1200 at 2OHMs and pushing each sub with 875rms... or is that not right? lol
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
Running parallel parallel would be .5 ohm
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
You want to run the amp at 1ohm not 2. I would just get another d2 and wire down to .5 and make sure you have the electrical to support the amp running at .5. Also why not go with a dc 1.2k to match the subs?
You need d4 coils. That simple
well i mean can they switch the voice coil to 4 if i asked? i'll get it switched out if its possible and if it doesn't cost alot of money. lol... and i dont know how much the DC1.2k is i just know that the AQ1200 is a good amp...
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
you would have to get a recone. for the level 3 to turn it into D4.
just run at .5 ohm. get a big battery under the hood with big 3 and most likely a better alt.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
