is there shops that will even flash the computr and raze the voltage? i have a 2004 expedition with a mechman 270amp alt. it charges higher if i have it at full tilt rite when the truck is started. i was just getting 14.5 out of it. some days it will only charge to 12.8 to 13.2.
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
Hmm could be batteries are a lil low so computer is telling it to charge at a higher voltage. I'm not sure what the regulator reads from and how it changes its charging rate. On newer chevy there's a thingy on the negative bat cable lol someone help what's the thing called
this is what i was thinking. you see when i go full tilt on my system the charging voltage goes up.
you have a beefed up alt that doesnt need to try so hard to keep everything in check. if im right after you rip on it for about 5 mins full tilt the voltage should increase by a fair amount once you turn it down. something like 14.3-14.5 for yours
mine did this once. was sitting at 14.4 then i railed on it for a couple mins, turned it down and it charged at 14.7 for a while
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
14.5 is the highist ive ever seen it in this truck :(. in my 2001 expedition same alt. i would sit at 15.2 cold wintr mornings. :) 14.8 hot.
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
It's called a dc alt...... My stock alternatoe charged at 14.4 no matter what. In the winter it would start at about 14.7. My 270xp won't charge above 14.1 if its more then 75 degrees out and that's just starting it cold. Once its warm I've never ever seen over 13.8 volts. When its above 85 out I usually dont see higher then 13.5. The alt does work. Voltage never actually drops but its never 14.4 that I though I paid for.... Sucks xs hasn't released a vcm for ford and it doesn't look like they will because I would be first in line for one.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
you are incorrect im having the same problem and i own a mechman
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
me too.lol its the ford computer what is bend us over. tahoes are the pussys way out.lol
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
  • Who's Online   0 Members, 0 Anonymous, 11541 Guests (See full list)
