well today i talk to a guy from soundstream and he told me that to get full power from my amp that i would have to use a 17 volt setup. so what do i need to get so i can have a 17 volts?
1991 Ford Explorer 1 Pioneer deh-p4000UB1 Memphis 16-st 20041 Pioneer Premier tsd720c
get a different sales rep bro. that's a bunch of B.S. that you need 17 volts on any amp
I got banned for being an ignorant ass....and im a dickhole
i like men, michael jackson and large sausages
ummm no its not BS.....that is how you get full power from some of the soundstream amps like the 6500 for example. (a few other brands too) I think its something like 2500 or 3000 at 14v but you dont get the 6500 till you go 16-18v..
its kinda dirty really to rate it like that since NO rookie or common stereo consumer will ever run a 16v system.....once youve competed for a while and you want to get full BURP power from an amp like that you up your voltage but its not for the inexperienced for sure.
Follow my Tweet (Twitter)
Yep. X2 what Meade says...With SPL Dynamics and American Bass amps...At least my model..IF I were to run 16.5 volts I would get 3000 watts @ 1ohm. But everyday 13.8 volts setups or 14.4 volts...I get 2000 @ 1ohm...Give or take a few watts... So it is not B.S. Check Amp guts on Realmofexcursion.com they have some good info on amp specifications...
OK let me re-phase that. it is a bunch of BS due to the fact that we, and i'm sure the sales rep, can tell your a little bit of a noob whhen it comes to 16-18v systems and he should have, if he was a good rep, recommended something you can have some knowledge about. a 17 volt system is something probably only a few people out there even run due to the complexity of the alty, battery, and relay configs and even i wouldn't do one unless i wanted to have a full blown SPL system for burps only. i didn't mean you can't a 17v amp rating we all know higher voltage = higher wattage ohm's law don't lie.
almost all amps that will fuction up to 18V are sure to make more power unless they are regulated right?
Correct, thats why I stick with unregulated powersupplies like my spl, and american bass
1 ohm @ 16.5 volts = 4500wrms.. now if you drop that puppy down into .5 ohms wow 5000+ watts :lol:
how bout the Soundstream XXX 10000........i just read some shit on "amp guts" and that thing only does 3600 watts on 14.4 volts.....oh man talk about overrated.
The soundstream are way bad if not at 18V
At the finals ya XS spl jeffery set a new world record in ss 1-2NW with their amp at 18V
But another competitor had 4 XXX 6500 a DC battery (the $$$ one) 2 12" DD 9500G and was not able to even qualify for world finals!!
I would not get those amps unless your going to do the 17 volts.... I researched it hundreds of times...move onto something else!!
  • Who's Online   0 Members, 0 Anonymous, 4925 Guests (See full list)
