I think the metal is steel, but what I am getting at is bending part of the stock alt bracket so my HO one will fit. I think it only needs to be bent a little. Was wondering if there is a way to do this with it still under the hood. I don't have access to a torch to heat the metal. Is there a proper way to do this or should I hit the f**k out of it for a little?( given I don't want to break anything)
Could you maybe sand it down for clearance? Heating it would be the easiest way, and hitting it could crack the metal
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
I'm on mobile so no pics right now. Cant sand or grind for clearance. It's not stainless or higher chrome alloy. It's just painted steel, I just need to bend like from say factory being at a 90 (vertical) a little piece of it at a 45 that is about 2 in long. It is the third arm to the stock alt(two sides like norm, then the metal I'm talking about to another bolt spot on the lower back of the stock alt)
Piece is about 1.5in wide too. Could I bend it with a wrench? Only reason I'm asking is because I don't want to take the alt off again if I don't know a probable way to bend it.(get some ideas then take a wack at it).
pic would be nice so we might come up with a better solution for you
REP
what engine is in your truck?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Is there a way you can take only the bracket off and leave the alt on?
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
my engine is the 5.7 vortec. I dont even have that bracket on it. of course its on the other side too. Id shave it down til it fit. the reason its there is to keep it from torquing when you hard shift and things like that.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1270 Guests (See full list)
